Question about Pitco Frialator 35C Deep Fryer
Our commercial pitco fryer shooting flames not all the time very scarey something we can replace???
    Problem Solver:
  • 11 Answers
Check burners and chambers for soot build up. Check gas regulator valve
Posted on May 13, 2010
I'm getting a lot of soot from my propane fired fryer. Otherwise works well.
The burner flames must be BLUE. Yellow flames will produce soot. Sounds like the burner orifice size needs to be checked.
Feb 27, 2016 | Pitco 40D Frialator - Commercial Fryer,...
My fryer is propane run and it sends out a flame about a foot up the stack at times how to fix t?
And you are sure you are not using Butane or some other gas?
Never use old or outdated gas burners, for your own safety.
Jul 17, 2014 | Pitco Frialator Kitchen Appliances -...
When i set the thermostat to desired setting flames shoot to the front of the fryer
Hi Dan.
Check if the fire tubes are clean, exhust system must be operating well during fryer operation. There should be no fresh air directed at the flue stack of the fryer, only exhaust.
Regards.
Oct 26, 2011 | Pitco Frialator SG14 Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
Pitco sg 18 s lpg
my friend it looks as if you have a leaking frypot. Do not use this fryer untill the frypot is replaced it is dangerous to use in this condition.
Sep 01, 2008 | Pitco Frialator SG18S Deep Fryer
Pitco sg14 commercial frier
id say change the valve that runs the gas has to be leaking
Feb 15, 2008 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
407 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
