Question about Poulan Weedeater/Electric Trimmer 4.1 Amp
Having a problem starting my Shindaiwa T22 Weed Eater.
Having a problem with my Shindaiwa T22 Weed Eater. Is the start/stop slide switch supposed to be forward or backward backward to start?
  • 64 Answers
Take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
Posted on May 04, 2010
  • shawn clarke Jun 16, 2010
    antonyo748
    trickle in some mixed gas into the carburetor throat and if it runs and dies the carburetor will probably need to be cleaned and rebuilt since sitting that long.
I have a Craftsman 2 cy. Gas Weed Eater, it has not been used for 3 yrs. I put in new gas, change a new spark plug, but it wont start up, what else can I do , to start it ?
Posted on Jun 15, 2010
I have a Shindaiwa weed eater 22 t while I was using it I accidentally hit the off switch when I try to start it again it wouldn't start I pulled the spark plug out to check to see if it was firing I...
Pull plug clamp battery charger jumper cable to body of plug other end to cylinder body pull starter rope and observe plug for firing at tip, you may need to darken room as some sparks are hard to see especially in sunlight.
Oct 06, 2017 | Light Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Swisher E4 (lack of power and rpm) ???
    Hi Davis:
    Check exhaust/muffler. Make sure it is not obstructed with carbon.
    Check trimmer string is not too long.
    Check air filter. Make sure it's clean
    What is history? Was it running well and then something specific happened?
    Spark plug - how long since it's been changed?
    Hope this helps.
    May 01, 2015 | Swisher E4 Shindaiwa 245cc Commercial...
    Weed eater troubleshooting
    Check the ground wire from the switch. The kill switch uses ground to kill the engine.
    Aug 20, 2014 | Craftsman Convertible 32cc Gas Line...
    I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
    If it is a pull start, leaving the switch on did no damage to the weed eater.
    Gary
    Jun 29, 2011 | Garden
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
    Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
    May 16, 2010 | Garden
    My te 475 weed eater wont start
    Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
    May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Poulan Weedeater/Electric Trimmer 4.1 Amp Logo
    1,403 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
