Question about Whirlpool WTW5300SQ Top Load Washer
Hi! Our newly installed Whirlpool WTW5200VQ washer has that horrid ATC, so the "warm" water is really "cool." And it takes 8 minutes for the 90% cold water + 10% hot water to fill a medium washer load. AND after a normal cycle, it automatically goes into extra rinse. I can't hear the noise unless I'm in the garage with the washer. I don't want to have to return the washer, but this is a mess! Thank you for any help you can give me.
Apparently, the only thing to do is contact Obama and have him institute a class action suit against Whirlpool, since this is such a widespread problem.
The problem is the frick'in washing machines won't do what they are suppossed to do, i.e., WASH CLOTHES. The machine owner is the one who can best determine what settings he wants to do his laundry on, NOT some WACKO who wants to tell you how much warm water HE thinks everyone should use, via temperature regulation switches/valves/whatevers.
I didn't buy a new washer to break my plumbing pipes, or to have to stand by and turn the dial after every step. I BOUGHT IT TO WASH MY CLOTHES (and towels and bedding, and maybe even my pet dolphin on the gentle cycle). I don't appreciate having to call the service department the day after delivery to come out and show me if I'm doing anything incorrectly. It should still be a 3-step process: 1) Put your clothes in machine. 2) Turn the machine on. 3) Put the clothes in the dryer when done.
I may return the machine if I don't get answers right away. And I will stop payment on my credit card if necessary. Fraud is fraud. The implied warranty of using the machine for its intended purpose is still valid.
Posted on May 17, 2010
  • Whirlpool Master
  • 8,220 Answers
Do you have those anti flood hoses? If so get rid of them and use the hoses that were provided.
Posted on May 02, 2010
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
I have a Whirlpool ywet3300sq1 that has decided to switch water temperatures on its own. This is not a new instalation which means the hoses are properly connected. On a regular cycle the cool is cold,...
Hell, my name is Troy, The part you need is actually the watervalve the atc is integrated into the tip of the watervale ... the watervalve is where you connect your fill hot and cold hoses too your stack washer dryer unit.. part number is #3979345 .. when you recieve part i would recommend using our technical phone support to assist you installing it...Have nice evening
DR.Appliance (Troy)
Feb 10, 2011 | Whirlpool Washing Machines
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool WTW5300SQ Top Load Washer Logo
488 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
