Question about Dishwashers
Dishwasher door leaks - Dishwashers
    Problem Solver:
  • 18 Answers
If the dishwasher is built-in check to make sure the door is closing all the way and not hanging up on the side cabinet near top of door. If the door is closing properly then inspect the door gasket for cracks, tears, areas that the seal needs seated back in slots, and any debris. If it is damaged in any way a new door gasket seal needs to be installed. www.selectparts.com should have the seal you need at a great price.
Posted on May 03, 2010
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Leaking from motor
Water Inlet Valve
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Seal
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
Maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Leaking door
Leaking Dishwasher
heatman101
Jun 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher leaks
Just about all dishwashers will leak a little around the door seal over time but should not leak to the point of wetting the floor. With the door open, check in the front of the tub, under the door. Lots of gunk? Clean this area out well plus take a soft damp rag and clean the door gasket while feeling for any damage. Then go along the mating surface of the door and look for any nicks. If it leaked all the time I would suspect the door hinges have been sprung. Hope this helps, Ken
Apr 26, 2009 | Dishwashers
Leak under door
Leaking Dishwasher
heatman101
s7657usut
Mar 07, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
263 people viewed this question
Top Dishwashers Experts
