Question about RCA HD52W58 52" TV
Tv won't turn on
Whenever I turn on the tv, it turns off and then on again 3 times. I have to wait a couple of minutes to try again. I would have to do this multiple times until the tv turns on. I've tried unplugging it for 10 minutes but still doesn't work. It does this both with the remote and the front panel.
Please help.
    Sergeant:
  • 418 Answers
These TVs have a self-check at turn-on, and will retry 3 x and then quit. Self-checks are like current overloads,voltages not present, IC communications not good, picture tubes not running. Can be anything without checking circuits.
Posted on May 03, 2010
Why does my LG tv seems like it need to warm up before it will accept HDMI signal?
Sounds like a capacitor fault. They can be intermittent when cold, but will work okay when warm. Eventually though they will fail.
This is your advance notice to get the set either repaired by the manufacturer or a local TV shop.
Sep 06, 2014 | LG 42LG50 42 in. LCD HDTV
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
My TV won't turn on. I have a 42" Sanyo LCD TV. We
You have a back light issue. Sometimes it's cheaper to get another one. Tcon board failure most likely. If you can find a rv repair or electronics repair they might do the work but as you got 5 years from it. Most TV sets fail in less time than that.
Jul 20, 2017 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My tv won't turn on anymore. The red light flashes 6 times then pauses for a couple seconds then starts flashing six times again. Just keeps doing it repeatedly
try unplugging the tv and waiting a minute and try it again if its still the same? It sounds like a Capicitor problem on the Power supply.
Dec 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My rca r52wh74 turns on for 10 secs then off.
was the storage unit climate controlled? If not then it's most likely due to heat and or humidity in which case I would suggest cleaning out the tv from the inside if you want to spend the time to do so but there is a good chance that the tv will need to be replaced.
May 31, 2009 | Televison & Video
Mitsubishi ws-65513
this is more than likely a case of the capacitors in your DM module failing. Email me at doin12volt at yahoo, and I will send you repair instructions.
Dec 30, 2008 | Mitsubishi WS-65513 65" Rear Projection...
RCA HD52W58 52" TV Logo
125 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
