Question about Kenmore Freezers
Does the kenmore cold spot chest freeze model 253.8193610 have a defrost timer
    President:
  • 2,976 Answers
Chest freezers don't normally self defrost. They just freeze. To defrost them, you must shut them off.
Posted on May 02, 2010
Only top section of chest freezer is freezing
Hi
Normally what causes the refrigerator/lower chest not to be cold enough is that the fan that pulls the air from the freezer is not working.
Check to make sure it is working, if not then you will have to replace it.
If it is working then check you defrost timer, it could be faulty.
I will include these two websites for parts.
partselect.com/
appliancepartspros.com/index.aspx
Please take time to rate me
Bud
Mar 15, 2013 | Freezers
Kenmore freezer gets cold and freezes but then completely dethaws itself
usually when aq defrost timer goes bad it gets stuck in defrost. I would suggest replacing this first
Mar 29, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Small chest freezer, running but not freezing, cold inside, everything defrosted
the freezer has a defrost timer and relay. if either is bad, it may get stuck in defrost mode(depending on what position the switch failed in). The fan will run constantly if this is the case. You may choose to follow the wiring diagram on the back of the service panel or hire a technician. If you do it yourself, unplug the unit for your safety
Nov 19, 2009 | Freezers
We have a Kenmore freezer chest...lights come on but doesnt freeze model#253.9135381 serial #s409256481
first,have you defrosted the frzr recently?they must be defrosted manually. take the 2 screws holding the side panel on and see if you hear the compressor humming/running. if you do. then the problem is in the sealed syetem. they should to come w/a 5yr. parts & labor warrenty but it looks like your frzr was build in the 1990's...
tip: if you think it's your cold control.you could unplug unit and use a wire,jump out the cold control.
Jul 16, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
107 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
