Question about Baumatic Upright Freezer BV12A
I want to clean the filters on my Baumatic Rangehood. I have removed them but can't find instructions about what to use eg very hot water? Warm? Detergent? etc
    President:
  • 2,976 Answers
The metal filters can be cleaned with ANY good degreaser. The carbon filters need to be replaced. Parts are available from the manufacturer or an appliance repair shop that handles your brand.
Posted on May 02, 2010
SOURCE:
How do I clean this machine?
you don't give a lot of information.
Outside with detergent and warm water. Stains with something like Comet.
Inside, if you have ice build up, switch the freezer off. Fill a bucket with hot water, and place inside for an hour. The ice build up will come off with a plastic scraper. DON'T use a knife! Wash down with soap and water, switch back on and leave an hour to get to temperature.
Aug 12, 2015 | Freezers
Sides of upright freezer are very warm to the touch
Good Afternoon Chuck, thank you for your inquiry! From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the freezer. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Aug 21, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hot side panels
Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Apr 24, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
Aug 17, 2011 | Whirlpool Freezers
Side by side freezer model ffv17f5hwd is not freezing the hi temp light is on and the temp inside the freezer is warm
have you tried a full defrost/filter and drain hole cleaning first.do not use hot water.......
Feb 06, 2010 | Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Freezer not cooling
ZoeM, I am thinking freeze up from humid conditions, too much 'window shopping' or bad door gasket (is that the seal of which you speak?). If the unit is only 9 months old...it has a full warranty. Don't do anything to it beyond what is described here.
Defrost the unit completely. If you can get warm air to the coils, do so. If not, leave it off and open for 2 days to completely defrost.
To check most door gaskets: first, make sure the gasket and its mating surface are both clean and visually undamaged. Next, test by simply closing the door on a piece of paper...use a strip about 2-3 inches wide and long enough to go inside the unit that you can slide across the gasket/frame surface. Close the door with the strip near any suspect areas. You should not be able to pull the strip out easily. Replace any damaged gaskets.
Dec 03, 2007 | Baumatic Upright Freezer BV12A
Baumatic Upright Freezer BV12A Logo
171 people viewed this question
Top Baumatic Freezers Experts
Dennis Boxerman
Marvin
Marvin
Are you a Baumatic Freezer Expert? Answer questions, earn points and help others
