Question about Fuji FinePix Z2 Digital Camera
Camera shows zoom error everytime i turn it on. how do i remove this
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
My camera sony smart zoom dsc-p43. everytime i
Hi there
First of all check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Pop it back in the camera and try to format the card again, if you get the same error message again there could be a chance the card is damaged.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Repair
i have a focus error that comes up everytime i turn my camera on. it wont let me take any pictures
Jan 29, 2008 | Fuji FinePix A500 Digital Camera
Fuji FinePix Z2 Digital Camera Logo
211 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
