Question about Power Acoustik MOFO-15 Car Subwoofer
My 15 was working fine and then it just stoped working. When I go over bumps it will kick on and then off. What can cause this problem?
  • Ronautotech May 11, 2010
    What type of terminals does the sub have?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Sound like you have a lose wire some wear. slammin with a 15 you gotta check all your screws every now and then LOL
Posted on May 06, 2010
When stoping i here a bumping noise
have your front-end checked, could be bad strut, shock-absorber, worn bushing @ control-arm, not good, unsafe, this could cause that bumping noise you hear, seek repair ASAP. avoid pot holes ! good luck
Feb 15, 2013 | 1999 Chevrolet Venture
Lights, windscreen whipers and inside car fan has stoped working all at the same time!
all of these devices have fuse in your kick panel (box beside gas pedal). most probably, the main wire connector in the kick panel became loose thats why all the devices failed at the same time
Jan 31, 2013 | Cars & Trucks
Vauxhall astra wont start
This make of car is not sold here inthe USA so we have no tech info on it. Sorry
May 27, 2012 | Vauxhall Astra Cars & Trucks
I have just bought my first Dt125r 2002 model. I can not kick start it and when I bump start it, it goes but no power and then cuts out after 10-15 secs
Usually this is caused by the air/fuel mixture not being optimal. Try adjusting the carburetor.
Please see the following link for an example.
http://www.youtube.com/watch?v=aUNU0G-Ofj4
If that does not work, check the spark plugs, they may be fouled.
Hope this helps!
Sep 06, 2011 | 2002 Yamaha DT 125 R
Odometer stopped working but the speedometer is working
I have just done some work on my ford escourt 75D
van the speedo was working perfectly fine & now its stoped working what could I have done to stop it working.
Baz
Jun 17, 2010 | 1991 Plymouth Sundance
04 suzuki rmz 250
Put in a new spark plug and check plug wire connections and ECM ground connections.
You probably have weak spark and when bump started the plug sparks strong enough to run the engine.
A weak battey can also cause this. Your ECM needs a minimum of 9V to work. (the ECM gives spark and timing) When kicking over, there is not enough volts to spark. When bumping over the alternator provides the extra volts to start the bike.
Hope this helps!
Rob
Sep 22, 2009 | Motorcycles
Going over bumps or bump roads, stearing shakes,pulls, at any speed fine after 15 min park
Please have a check at your steering rack and your shocks.
But I have a strong belief it could be your steering rack.
Rate this
Apr 15, 2009 | Toyota Tacoma Cars & Trucks
Is it my battery?
well this is what you should try ,,jump the car get it running
then when its warmed up take the positive lead of the battery
if the car stops the alternator is gone (thats what charges the battery) if the car runs its fine
and if u have put another new battery in it and the alternator is fine look for any broken wires earths or positives that could be making it drain so quick
and make sure your battery levels are full
hope this helps
Jul 02, 2008 | 2001 Mercury Cougar
Power Acoustik MOFO-15 Car Subwoofer Logo
66 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
