Question about RCA L52FHD38 52.1 in. HDTV LCD TV
L52FHD38 DVI to HDMI connection with a Mac Mini. I have a 2.26 GHz Intel Core 2 Duo Mac Mini and a DVI to HDMI adapter. The adapter, when plugged into my Toshiba HDTV downstairs requires nothing from me: it just works. When I use the same cable and the same settings with my RCA--into the HDMI port and all that--I get unusable signal. Is there some sort of driver weirdness or other thing that I should know. Like I said, the setup and the cable work fine--just not with this TV. Thanks
  • RCA Master
  • 5,188 Answers
You are using the same cable and computer on both TVs if I follow you correctly. Is it single link or dual link DVI? The two are different and can be a factor.
Did you plug into the HDMI/DVI port or the HDMI 1 port? Make sure to use the HDMI/DVI port.
As far as I know, the Mac should be able to load the drivers for both TVs. However, my manual for this TV doesn't mention OS limitations.
I hope this helps.
Posted on May 02, 2010
What cable is needed to stream Netflix to a Macbook?
If you want to use a TV as a secondary or mirrored monitor. All you would need is a Mini-DVI to HDMI adapter. Use the adapter to connect an HDMI cable between your computer and the TV. Once connected you will have an option to use it as a secondary or mirrored (exact copy of what is on your laptop) monitor. If you have one of the newer macbook pros you need a Mini Display port to HDMI adapter.
Jul 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How can i add monitor with hdmi cable to an hP all in one computer
Hello Anon,
I believe your P.C. has a DVI socket on the back, if it is a DVI-D, it only carries digital signals. If it is a DVI-I socket, it carries both digital and analogue signals, either way, you need to get a DVI-to-HDMI adaptor, (Ebay or Amazon), connect it to the DVI socket on your P.C. then plug your HDMI lead into it and the monitor.
Regards,
Ron.
Jun 07, 2014 | Averatec D1002UHCE-1 All-In-One Intel...
How can I boost up mac mini 2007
Your best bet beyond maxing out memory will be upgrading to an SSD. Depending on your operating system and versions of installed software, try using a program like XSlimmer to remove any powerpc files included in universal bundles.
Oct 09, 2012 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
I'm trying to plug my laptop into a tv to display my desktop and I can't seem to do it. I got a vga adapter and cord that is plugged into both the tv and laptop. What am I doing wrong?
The 13" White MacBook 2.0GHz has a mini-DVI out port. The adapter you need is
Apple Mini DVI to VGA Adapter
On the TV side, more information is needed. You need to specify what ports on the TV you are using for your signal, and what kind of adapter cable you are using. I suspect this is the component or connection where your problem lies.
May 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Is these a driver to get USB connection to macbook
Are you asking if there is an adapter? There actually is an adapter (USB to S-Video) that will work between the two. However, with my MacBook C2D 2.4 GHZ, I use mini DVI to VGA adapter. This allows instant laptop to projector picture and sound. You can use it for anything from powerpoint to movies or even as a giant monitor. The mini-DVI to VGA adapter can be purchased at Best Buy for less than $20. Look for it in the accessory aisle near the Apple machines. IMO, this is a priceless addition to your MacBook. I hope this helps! Please remember to vote if it does.
Jan 27, 2010 | Apple MacBook Pro Laptop Computer with...
How do I connect my macbook pro to a Pioneer Elite HDTV?
Newegg.com carries a mini-dvi to hdmi cable that
Item#:N82E16812200375 it's listed as "StarTech MDVIHDMIMF Mini DVI to HDMI Video Cable Adapter for Macbooks and iMacs"This should hook directly into one of your HDMI connectors on your HDTV.
Hope that helps
Oct 31, 2009 | Apple MacBook Pro Laptop Computer with...
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Can I use an Apple M7649 Studio Display with a MacBook Pro
Do you have the black unibody Macbook Pro that was just released, or the silver model?
Since the display is DVI, it will directly hook up to the silver model. If you have the new model, you need a mini DVI to DVI adapter.
Nov 22, 2008 | Computers & Internet
RCA L52FHD38 52.1 in. HDTV LCD TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
