Question about Whirlpool LEB6300 Electric Dryer
4 wire hook up ,where does green and white wire from unit connect
Where does green wire from drier switch connect to neutral or hot
  • Whirlpool Master
  • 2,605 Answers
Hi Larry, The green wire is colored green to identify "earth" meaning it is a ground. Do not connect to "hot" nor "neutral", it MUST be connected to the chassis/ground only. That should answer your question. Thanks for coming to "fixya" and please take a second to rate this answer according to it's helpfulness. Good luck macmarkus :)
Posted on May 02, 2010
  • Mark MacDonald
    Mark MacDonald May 07, 2010
    Hey Larry,
    I finally got my pc back working after a short power outage, yipee !
    My first reply was on my iphone so I was limited to what I could provide.
    Here's an image which should help, let me know.
    macmarkus :)
  • Whirlpool Master
  • 8,220 Answers
Ok lets talk about it for a minute. All dryers are not the same. You need to consult the installation instructions. The cord has 4 wires. Red,Black,White,and Green. The white wire has traduionally been used on appliances as a common wire and mounts in the center. It always gets mounted in the center terminal so that it can feed both sides. It IS the common feed from the power source for both sides of the breaker. The red and the black wires are each 125 volt hot wires an as you may know mount to each side of neutral (white). The green wire is a safety wire. It provides an extra path for electricity to earth in case of a direct shorted live wire to cabinet. So... you need to attach the green wire directly to the frame of the appliance. BUT you need to see according to the install directions if the metal stirp between white and frame gets removed or stay put. You got to get it right because if the electronics **** out and the techs come out they look for flawed installs. Anythang weird voids the warranty.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Which way do the wires connect to a 3 tab lighted rocker switch using black white and green wires
Usually the center tab is COM... connect Black Hot wire
Other two tabs are switched... connect Black going to load to either of the tabs.
Connect White neutral to load neutral
Green wire is ground... connect to green ground screw or bare copper.
Test wires to see which is hot and neutral
http://waterheatertimer.org/Basic-house-wiring.html#test
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2014 | Electrical Supplies
The wires for hooking this fan up are white,black and blue my guess is white and black are hot and blue is a ground wire. is this right?
White (Neutral) White to White
Blue (Light to Hot) Blue to Black (optional)
Black (Fan to Hot) Black to Black
Green (Ground to Ground) Green to Green
If you do not have a green lead you might see a green screw to attach the ground wire from the house power. The fan has the optional light fixture future connect the blue wire to the black hot wire. If you have the optional light fixture you may want to connect it to a separate switch power.
Jan 14, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
I have a Cooper Triple Single Pole Switch. I want to connect my bath light and fan combo unit and a separate light above my mirror. If I plug the HOT wire to the single black screw, that leaves me with 4...
The information is a bit sketchy, and you can add a comment with more information.
1) You have a triple switch with dark screw
(s) on one side of device.
You know that Hot attaches to dark screw.
On opposite side of switch are 3 screws.
1 screw is for wire going to bath fan.
1 screw is for wire going to bath light.
1 screw is for wire going to separate light above mirror.
If you do not have a separate wire running to each Load, then you need to add a wire.
2) If I understand correctly, your wall box contains several cables
Each cable has a black and white wire.
Ground wires are twisted together and connected to green screw, and are not discussed.
3) Cable1 black and white are Hot and Neutral from breaker box.
Are you sure?
Test each wire in box to bare ground to find hot wire.
Test hot wire to each wire to find neutral wire.
If power comes from junction box on ceiling, wall box might not have neutral wire.
If neutral wire was used to complete circuits for previous switch, then it is used the same for new switch. That's where the information is sketchy.
You have 4 white wires
1 white goes to each load
1 white is neutral
Where are the black wires associated with these white wires?
Add a comment and say how many cables and where each wire was connected before.
Here's how to start.
Connect Hot to dark screw.
One at a time, connect each white to screw on other side of switch.
Turn on power and flip the switch.
If load turns ON, then that wire is correct.
If load does not turn ON, then leave switch ON. Test each of the other white wires to bare ground to see if this wire should connect to neutral. Then connect that wire to neutral and test switch again.
Nov 16, 2010 | Cooper Wiring Devices Triple Deco Single...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
Installing a GE digital wall timer. Instructions say" connect Hot/live wire of main to black of timer. Connect Hot/live wire of load to red of timer. connect white of (neutral) to white of timer. green...
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Sep 25, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
How do i hook up a 4 wire timer switch (R G B W) to a three wire box(G B W)?
Generally your hook up is like this.
G - Ground - Green or bare wire
B - Hot - Black wire
W - Neutral - White wire
R - Switched - Hot when on
On your three wire
B - Hot - Black wire - hook to switch wire from switch
you should also check: http://www.intermatic.com
Jun 04, 2010 | Intermatic EI210 Electronic Auto Shutoff...
My house wires from the electic stove top has 3 wires and my new bosch electric top has 4 on red, white, green, yellow?
hook the red and yellow off the new stove to the two hot phases-then connect the white on the new unit to the neutral power connection and finally the green wire can hook to the same neutral wire also as long as the power comes directly from the main electrical panel in the home, but not a sub-panel
Nov 15, 2009 | Bosch 30 in. NET7452UC Electric Cooktop
Changing my dryer cord from 3 pronge to a 4 pronge. how do i hook the cords to the baqck of the dryer. brand name is a frigidaire
on 4 wire, red and black is hot, white is neutral and green is ground. On terminal block out side terminals are hot and center is neutral, ground connects to green screw on cabinet. if your current connection has a white or green/yellow jumper on the ground term move this to the center/neutral connection with the white wire. only wire to be on gnd term in gnd wire. hot does not matter which side as long as it doesnt touch anything else and not on center term.
Difference in 3 and 4 is a dedicated ground, on 3 wire dryer was grounded through the neutral.
May 03, 2009 | Dryers
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
