Question about GE Energy Star WCVH6260F Front Load Washer
I can not get the door gasket on. My dog literally chew up the old rubber gasket. I got it off but I cant get the new one one.
Hi
Thanks for using FixYa. To replace the gasket please follow these
step by step instructions: First of all please unplug the washer from the power supply socket.
1. Now remove the plastic cover on top of machine
which is mounted on back of the control panel.
2. Remove
dispenser - push down on tab at back and it will slide all the way out.
3. Remove
lower front cover by removing screws holding it on bottom.
4. Remove
screws holding top panel on back of machine and slide cover back approximately
1 inch and lift off.
5. Remove
the screws that hold the control panel on (these are different type of screw so
keep track of which screw goes where) one of the screws is next to dispenser
opening. Once this is done you can reach in to machine and disengage locking
tab on right side under "washer temp" - have someone hold this part
aside if you do not want to disconnect the cables.
6. Remove spring loaded wire securing door
seal to front cover (the spring loaded wire is in the front of the gasket under
seal).
7. Remove the screws holding the front cover
on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness
and place this aside.
8. On the
right side of the gasket you will find the clamp screw that holds the seal to
the drum - loosen this screw almost all the way and remove this wire clamp. Carefully
remove the two tube connections and remove the gasket completely. Take note how
these were installed before removing. Now you can carefully clean the gasket
seats on the drown and door and replace the gasket and reverse the steps to put
the machine together. While you have the covers off it would make sense to
remove and clean the pump strainer mounted on the lower cross support - this
can be messy with lots of water coming out so go slowly and have plenty of
towels and a shallow pan to catch the water with.
Please do accept the solution if the issue is resolved else revert
for further assistance.
Thanks
Rylee
Posted on May 02, 2010
Nov 30, 2017 | Dogs
Aug 23, 2012 | Baby Einstein Dogs
Most of the rawhide treats are made from premium beef hide from
corn-fed American cattle, and produced under the strictest quality standards
and under the supervision of the Health Minister.
Aug 15, 2012 | Dogs
I have spoken to my veterinarian and she said that long-lasting chew treats can provide your dog with many dental benefits. If your dog spends 30 minutes daily chewing something like rawhide will have optimal dental cleansing benefits.
Jul 23, 2012 | Dogs
Jul 23, 2012 | Dogs
Jul 23, 2012 | Dogs
Jul 23, 2012 | Dogs
May 20, 2010 | Audio Players & Recorders
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
