Question about Staples SPLXC200D Shredder
I cannot find a 7 amp, 125 volt fuse that is three quarters of an inch long. It is a Staples Shredder and I have tried numerous places and cannot get one.
The shredder is saying the door is open but there is no door on the shredder
It may not be a 'door' but there is a protective cover over the shredder blades and that can be removed. A sensor sees if it is properly in place. Try removing the top and replacing (power off of course)
Apr 24, 2014 | Staples Office Equipment & Supplies
The fuse is blown. Where can I get one. Circuit board says 5A 125 volt, but the fuse says 6.25A 250 volt.
Replace the fuse...not what is written on the circut board....Radio Shack or any electrical repair outlet will have fuses.
Feb 11, 2011 | Royal 1280MX Shredder
Paper is stuck in my shredder and the reverse button doesn't even reverse it out. Please help what do I do? staples mail mates shredder'
turn the shredder off by disconnecting the plug from the socket find a flat instrument that will not damage the blades and try and manual move the blades. I would advise using thick gloves whilst doing this to prevent any cuts or bumps. You will also need to lubricate the shredder for it to move freely, find some good machine oil or shredder oil and lubricate this may also help in the process of freeing the jam,
Good luck
Nov 11, 2009 | 2005 Kanuni Cheetah 125
No power to Staples mailmate
There is a 10mm 5amp @ 250v fuse on the main board that is probally blown . I unsoldered mine and soldered a pigtail fuse holder with a convient sized 5 amp fuse inside in its place . The shredder is not too bad to take apart , the head comes apart from the body of the shredder .Turn it upside down and you will see 6 or 7 phillips screws .Once these are removed the head assembly opens up and you will see the circuit board which is held in place by 2 phillips screws. A quick ohm meter test will reveal the fuse condition. It was an easy fix just MAKE SURE YOU KEEP THE UNIT UNPOWERED while you work on it or its unassembled.
Jun 24, 2009 | Office Equipment & Supplies
My son's 2005 Kymco TGB 50cc scotter hit a good
Normally, one goes to the carb, one to the gearbox and one to the battery. What sounds really weird is the diameter of the hoses. Three quarter and one inch diameter? Normally 1/4" to 3/8".
Hope this helps!
Please rate this solution. Thanks locjaw69!
Apr 04, 2009 | 2005 Kymco Stryker 125
Mailmate by staples shredder won't turn on
I took my mailmate out into the driveway. got in my truck and ran over it two or three times. it doesn't work any better but I feel great.
Oct 25, 2008 | Office Equipment & Supplies
Shredder won't turn on
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
Aug 24, 2008 | Office Depot Ativa DQ60M Shredder
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
Staples SPLXC200D Shredder Logo
297 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
