Question about Armitron 40/8125BLK Digital Sport Watch
40/8125 - how do i set time and 24hr time and chime
    Genius:
  • 1,157 Answers
Hi mslichter99,
To set the time and date of your Armitron watch, please follow the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 12, 2011
    President:
  • 2,501 Answers
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file
Posted on May 03, 2010
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
Clipsal IP56 24hr timer switch system for pool pump. The 24hr timer isn't working. I'm not sure if it's something I'm doing wrong or the timer is faulty. I'm just guessing on how it works, so it's lik
If the timer dial does not keep the correct time then the timer unit is faulty and needs to be replaced.
There are gears in the timer unit that trip the ON and OFF time settings.
From what you describe it appears you have a faulty timer.
Oct 04, 2012 | Watches
I just bought an adidas ADH4033. I have read through the manual thousands of times and have figured out how to change the hours on the watch but still cannot change the minutes, date, 12/24 hour, or any...
this might help. press and hold top right button to change to T1 or time 1. press and hold top left button and u will see ' light on/off' on display. press bottom left button to set chime. press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking. press top right button to change to preferred hour. press bottom left button to navigate to hour, min,sec use right buttons to select numbers.
Aug 27, 2011 | Watches
How to set time and date on kenneth cole watch model a126-03 rk5033
I had 2 problems:
1- my watch was stuck in 24hr time format.
2- I didn't know how to turn the alarm off.
Solution for issue #1 (switching between 24hr and 12hr time displays):
You press both the upper right and lower left button at the same time's
Solution for issue #2 (turning alarm on/off):
You press both the upper right and lower right button at the same time, twice.
Apr 14, 2011 | Kenneth Cole RK5034 REACTION
I have a new invicta watch model number 6089 that I just recived yesterday. I can set the time and date but for some reason I can not set the 3 arm?? I have read the instructions and still it will not...
The trick to setting the 24hr hand on the 6089 is to pull the crown out only one notch (not two) before using the upper push button to change the time. As it's a 24hr hand, the best time to set it is at the top of the hour.
Feb 05, 2011 | Invicta Watches
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Armitron 40/8125BLK  Digital Sport Watch Logo
185 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you an Armitron Watch Expert? Answer questions, earn points and help others
