Question about Zenith Z50PX2D 50 in. Plasma HDTV
Zenith PDP50x3000 Found this TV with a missing power supply board. I read this is a troublesome unit. Is it worth risking getting the PS and finding it has other problems?
  • Julio Hernandez
    Julio Hernandez May 11, 2010
    Found? as in -someone got rid of it?
  • Zenith Master
  • 8,457 Answers
This brand is ok,it have it problems just like any other
Plasma tv brand.The only thing is Zenith tv is not a popular tv brand of tv anymore.Have very limited refurbishable boards parts to buy for the tv replacement.
Posted on May 02, 2010
  • Chi Chu May 02, 2010
    Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suppply board for the replacement.I would tries to fix this tv,because it a 50"inches the brand new 50"inches tv would of cost u $1,400-1,500 dollars easyly.
Trying to repair a samsung led tv. It was struck by lightening. There are 4 boards in the tv. Do you think if I replace all 4 boards it would work? Could the lightening have damaged the led screen?
any answer here will be pure guessing. and the cost versus the risk of not working by replacing all four boards may make it worth buying a new tv instead.
if you were to try and fix it i would not do anything more than trying to fix or replace the power supply board. . if the power surge has gone further in the electronics. its rarely worth trying to fix
Nov 14, 2016 | Samsung Televison & Video
Picture focus getting worse & worse; now sound becoming intermittent
You are most likely getting bad capacitors in the main power supply as well as the sweep power supplies. Looking at the age of this unit, the cost to replace the power supply, it will cost you about 350 to 450 to repair this set. You MAY ALSO need to replace the High voltage/ sweep board as well. The best way to properly tell would be to call out a factory authorized Zenith repair center. They should have all the boards available to test the TV with. That would also be a bit more to repair. In my opinion, the cost would not justify the repair. Good Luck with your TV set.
Jan 15, 2008 | Zenith IQB55M90W 55" Rear Projection...
Zenith L20V34S Completely DEAD Zenith LCD flat screen 20in Model: L20V34S Manufactered: Oct 2005 Listed HealthCare Facility TV Hello all, TV wont turn on (no red light either)after turning it...
The tv now is completely dead,no LED power light indication at all?Yes,than the tv power supply board 90-95% it is alway the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Zenith L13V36 LCD TV
T.V. wont turn on. Can get it to turn on if you click it about 200+ times.
The tv power supply board is dying and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whloe refurbish power supply board for the replacement.
Dec 28, 2010 | Zenith Z50P3 50 in. Plasma TV
Zenith tv dosen't work
Power supply Board Call UED 1-800-648-6657 or try Encompass 1-800-638-3328
Dec 07, 2009 | Zenith E44W46LCD 44" Rear Projection...
Turn on lg 42''plasma tv.get sound but no picture
Failure in either of the following can cause no video output.
  1. Panel
  2. Y Drive Board
  3. Y SUS Board
  4. X Drive Boards
  5. Tape Carrier Package (TCP)
  6. Main Board
Try these if you have electronics background :
Note: Touch your fingers repeatedly to a ground connection point or unpainted metal in the product before proceeding.
  1. Unplug the unit.
  2. Remove the back cover by removing the screws holding it. No need to remove the stand.
  3. Disconnect the LVDS cable from the power supply or from the main board. LVDS cable runs from the right bottom of the power supply to the upper left of the main board. Power supply is located at the upper center of the unit and the main board is at the right bottom of the unit.
  4. Plug the unit back and turn it on or the unit turns on automatically.
  5. Look for the Control Board. It is located right at the center of the unit below the power supply. It has a LED on it.
  6. On the Control Board at the right bottom of the MCM chip, the big chip right at the center of the board, you can see two test points. Short across the two test points.
  7. If there appears a picture of cycling colors and patterns, the Y-SUS, Y-Drive, Z-SUS, Power Supply, X-Boards, TCPs and Panel are all OK. The Main Board or the LVDS cable is defective.
  8. Check LVDS cable continuity.
  9. Replace Main Board if LVDS cable is good.
  10. If no picture of cycling colors appeared on step 6, some adjustment is off or some portion of the signal is missing.
  11. Check fuses or continuity of voltage supply lines going to the X Board/s, Y SUS and Y drive Boards and Z SUS Board.
  12. Replace blown fuses, connect broken lines, and resolder loose solders.
  13. If no apparent damage is found, ask for a qualified or experienced technician's service. Massive and sophisticated tests and voltage readings are required and proper tools are needed such as oscilloscope to find which signal is missing. The parts to be tested are prone to handling damage and requires proper handling and testing.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
Zenith PVY6067DT Starsight - 1996 No Picture No Sound
i just bought one of these with the same problem and had a repair man come over. said it has a h.v. power supply problem even though the red light is on and some little board cant read the handwrighting on estimate but will follow up. must replace the whole board the power supply sits on, it is the big board that the power cord connects to in the back of the tv... other board it is located behind the little panel in between the speekers on the front it is the little one in the left hand top corner. parts/labor mainly parts +/-$500. is it worth it? ihave not seen this tv working so if there are any comments about the picture quality i woul like to hear/read them. hope this helps.
Oct 11, 2007 | Zenith IQB50M90W 50" Rear Projection...
Zenith TV B32A24Z
You have a power supply problem. On this set the entire board is available for exchange but it is most likely not going to be worth the repair as these boards run for about 120 to 145 bucks. Good luck
Jun 05, 2007 | Zenith B32A24Z 32" TV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
554 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
