Question about Royal Sovereign ARP-1000EX Portable Air Conditioner
Fitting vents in the window
I am unable to use the extensions on the plate that holds the vents in the window. With out the extensions I and about 3" short. Should I cut one of the extensions or is there smething else Ican buy to get is sealed in the window?
Thanks
Mike McHugh
    Novelist:
  • 135 Answers
Mike,
what I usually do in this case is to remove one side of the curtains. This is usually the fastest and I have not been able to find factory curtains that are any narrower than whats on the A/C out of the box. Good Luck and have a great day.
Contact me back if I can help you any more.
Sincerely,
Paul Gibson
Posted on May 03, 2010
How to replace clutch
disconnect battery, remove screws holding floor down, the part covering the gearbox, remove starter motor, unbolt driveshaft at gearbox end, remove tin cover bottom of bellhousing, undo rear mount bolts, remove all bell housing bolts, with front seats removed you can lift the gearbox out of the car, ensure anexact alignment of the clutch plate and pilot bearing in the flywheel when fitting new parts, you can use a small socket and extension bar to align them. reverse procedure to refit components. good luck.
Jun 20, 2014 | 1969 Morris Minor
Paper tray not fitting in CP1215
Hi, Dorothy,
The CP1215 color laser printer's paper tray defaults to the A4 paper size. However it has an extension at the front that allows for the selection of the JIS B5 paper specification which is longer than A4's 11 inches by the 2 inches you talk about. To release the paper extension, you hold and pull out the middle light blue tab (there are 3 Tabs) that is in the paper tray. The extension will slide out to length of about 2 inches that then juts out when you install the paper tray back into the printer as is in your case. To slide it back, you hold the right-most blue tab and push the extension in back to the A4 paper size. I hope this helps.
Apr 04, 2014 | HP LaserJet CP1215 Color Printer
Some icons on desktop not fitting on screen
1. Hold 'Windows + X'
2. Click 'Disconnect display' or if not connected 'Connect Display'
3. Select 'Projector only'
N.B: This is for windows 7
Jan 05, 2013 | Google Chrome
Fuel leaking out of 2 hoses connected to the carb cant stop the fuel leak
Inspect the fuel inlet hose closely. If you notice a wet spot around the hose where it joins the carburetor fitting, or the hose has become swollen, soft, brittle or hard, replace the fuel hose and the small fuel filter inside the carburetor fitting. Install a new worm clamp to tighten the new fuel hose to the fitting. Use a Phillips screwdriver.
Check for a fuel leak around the accelerator-pump cover assembly. Some carburetor models come equipped with a diaphragm-accelerator pump on the side of the unit. If the cover screws have come loose, fuel will leak through the diaphragm and external cover. Look for a square cover on the side of the carburetor and tighten the cover mounting screws at each corner with a Phillips screwdriver.
Look around the gasket located between the carburetor upper body and the main, or lower body. This gasket may have worn out or the carburetor upper body mounting screws may have become loose, allowing fuel to leak outside the carburetor.
Ensure the upper body mounting screws are tight, if you found a leak. If they are tight, remove the clip holding the throttle linkage to the carburetor with a pair of needle-nose pliers and reposition the linkage to the side. The linkage allows the driver to operate the throttle plates in the carburetor through a cable when depressing the accelerator pedal. Unfasten the screws holding the carburetor upper body from the main body with a ratchet, short ratchet extension and socket. Remove the old gasket and install a new one.
Inspect around the bottom of the carburetor where it joins the intake manifold if no leaks were found around the gasket located between the carburetor upper body and the main, or lower body. If you find a wet spots or marks around the bottom of the carburetor, the base plate gasket is leaking. Remove the upper and main carburetor body using a ratchet, short ratchet extension and socket. Install a new base gasket and replace the carburetor assembly.
Jan 21, 2012 | 2009 CCM RL 125
I dont know how to remove my battery something s holding it down but i see no bolt. 2000 lincoln continental
On one of the side is a hold down its in either side if your battery youll need a extension , with a 13mm or 1/2, or its a 15mm nut with a hold down plate, just unscrew, and remove plate its about 3 inches long and 2 inches wide and out the battery comes
May 03, 2011 | 2000 Lincoln Continental
What is holding the battery in the tray and what size is the nut? I think one would need an extension?
you will need an extension and a1/2"(13mm)socket to remove the bolt/nut holding the battery hold down plate.there should be nut along the long side of the battery on one side or the other of the battery,remove this and then remove the hold down plate then you can remove the battery.
Apr 24, 2011 | Chevrolet Uplander LT Cars & Trucks
The 4 wheel drive shifter is broken. How does the linkage to the transfer case come apart?
Shift Lever NOTE: Remove the shift ball only if the shift ball, boot or lever (7E067) is being replaced.
Removal
  1. Raise vehicle on hoist and position suitable safety stands under vehicle.
  1. Prior to removing the control lever assembly (7E069), be sure the shifter is in the 2H position.
  1. Loosen (do not remove) the nut retaining the shift handle (7E067) to the control lever assembly (7E069). Remove the shift handle (7E067) from the control lever assembly (7E069).
  1. Remove the vent hose (7D494) from the notch in the detent plate.
  1. Remove the control rod (7A315) from the control lever assembly (7E069). ani_caut.gif CAUTION: When removing the control rod (7A315) off the control lever assembly (7E069), do so very gently so as not to damage the control lever assembly.
  1. Loosen (do not remove) the large pivot bolt holding the control lever assembly (7E069) to the detent plate.
  1. Swing the control lever assembly (7E069) out of the way and remove the two bolts (39129-S2) retaining the detent plate to the transmission extension housing. Remove the entire control lever assembly from the vehicle.
Installation
  1. Prior to installing the control lever assembly, be sure the transfer case link (7B106) is in the 2H position (pointing upward).
  1. Install the two bolts (39129-S2) to retain the control lever assembly (7E069) to the transmission extension housing and tighten to 92-125 Nm (68-92 ft-lb). Refer to the following illustration for bolt hole application.
  1. Attach the control rod (7A315) to the control lever assembly (7E069).
  1. Tighten the large pivot bolt to 92-125 Nm (68-92 ft-lb).
  1. Attach the vent hose (7D494) into the notch in the detent plate so the white mark is flush to the outside surface of the plate.
  1. Install the shift handle (7E067) into the control lever assembly (7E069). Tighten the retaining nut to 27-38 Nm (20-28 ft-lb).
  1. Check transfer case for proper shifting and operation.
Feb 27, 2010 | 1992 Ford F250
2001 dodge ram 1500 4x4 vent hose on rear axel
The hose is only an extension to elevate the vent. Trucks have these so they can be braver about crossing axle deep water.. The plastic piece on the end is somewhat of a chk valve so the hose isn't open to dirt and road spray.It should be cliped to the frame to stay elevated.
Jun 08, 2009 | 2001 Dodge Ram 1500 Truck 2WD
How to change spark plugs on 2002 mk4 automatic golf
1 - High Tension cable
  • 4 to 8 Kohms
  • With suppression connector and spark plug connector
  • Only remove and install spark plug connector using tool T10029
2 - Ignition coil with output stage (-N70-, -N127-, -N291-, -N292-)
Connection, ignition wires:
  • HV1 = Cylinder 1
  • HV2 = Cylinder 2
  • HV3 = Cylinder 3
  • HV4 = Cylinder 4
3 - 10 Nm 4 - Connector
  • 6 pin
5 - Knock sensor 1 -G61-*
  • Contacts gold plated
  • Fitting location: Cylinder block intake side
6 - 2-pin connector
  • For knock sensor 1 -G61-
  • Do not interchange
7 - Knock sensor 2 -G66-*
8 - 2-pin connector
  • For knock sensor 2 -G66-
9 - 20 Nm
  • Tightening torque influences the function of the knock sensor
10 - Spark plug, 30 Nm
  • Type and electrode gap See test data, spark plugs.
  • Remove and install with 3122B
11 - Connector
  • 3 pin
12 - 10 Nm 13 - 100 Nm
  • Use counter- hold tool 3415 to loosen and tighten
14 - Camshaft sprocket
  • With rotor for Camshaft Position (CMP) sensor
15 - Camshaft Position (CMP) sensor -G40-* 16 - Bracket
  • For Camshaft Position (CMP) sensor
Jun 04, 2009 | 2002 Volkswagen Golf
Cannot load office outlook 2003
Try uninstalling Outlook then reinstalling it. Good Luck!
Nov 15, 2008 | Microsoft Office Outlook 2003 for PC
Royal Sovereign ARP-1000EX Portable Air Conditioner Logo
130 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
