Question about Microsoft Xbox 360 Elite Console
I recently set the timer on my son's xbox live to limit him to 4 hours per day of play time, but the timer is apparently not working. He is still playing for alot more than 4 hours per day.
He must have changed it back, change your parental code and switch it to 4 hours, once more.
Posted on May 02, 2010
If my son has XBox Live Gold Membership do we just need an internet connection to play or do we require extra GB per month to play?
The xbox live gold membership is paid for when you buy it. It never runs out until you have used all of the time you bought. Like say you bought a 12 month subscription it will last you the whole year until the day you bought the last one and activated it. Only time you use money is when you want to buy something from xbox live. All you need is the internet wifi or direct cable works. You can actually use your xbox live account on any xbox. Say if his friend has an xbox and has xbox live he can then use his account on his friends xbox to play online with his friend. You dont have to worry though every time he goes to an xbox he has to recover his xbox live account info so no one else can use it while he is using it. There is also a few new updates to keep his account safe as well when he does want to do something like that. also you can go into family settings and make it so he cant buy anything with out a pass code even put a timer on it with a pass code to limit time of play. So inclosing no you dont have to buy GB it just uses your internet connection and it does cover the cost of play for as long as you bought the subscription. Hope this helps :)
Feb 22, 2014 | Microsoft Xbox 360 Console
I've got a uplay account so does this mean that my friends that play with me must also get one or what?
This means you don't have xbox live gold membership , you will need xbox live gold membership in order to play online
or if you have any free xbox live trials like 48 hours or 14 day , use it you can access online features in those limited time
hope this helps :)
Dec 20, 2012 | Video Game Consoles & Games
Can not set up my hydrofarm timer to come on for 1 min and off for 5 min.
You posted next to a photo showing hydrofarm analog timer with segments located on dial face.
Open following link for general look at setting analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Analog timers have a minimum set time of 15 minutes because the trippers-or-pins-or-segments are made certain width.
If you want 1 minute ON and 5 minutes OFF, you need digital timer.
Most digital timers have minimum set time of 1 minute.
But digital timers have limited number of set points per day unless you get into heavy-duty Intermatic timer like the ET70115 timer with 100 or so set points.
If you want 1 minute on and then 5 minutes off, and want to repeat that same cycle over and over throughout the day and night, you would need 240 set points.
Or check out 120V adjustable cycle timers.
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
If you want the cycle timer to operate certain hours only, then put ordinary 24-hour timer between the cycle timer and the load.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Hydrofarm Timer 24 Hour
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Set time
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
How do you set up xbox live?
Here is a relatively simple guide that will assist you in getting your Xbox connected to Xbox LIVE:
http://support.xbox.com/support/en/us/xbox360/xboxlive/getconnected/hcxl/getstarted.aspx
There are currently two options, Xbox LIVE Free and Xbox LIVE Gold. If you wish to play multiplayer games, you'll need a Gold account. Xbox 360 consoles come with a time-limited trial of Xbox LIVE Gold.
Remember to rate my solutions! If you have time, drop a testimonial too - they really make my day. :)
Mar 30, 2010 | Microsoft Xbox Console
I want to program my 360 to shut off at a certain
If your wondering if there is a timer built inside you can set unfortunately there is not. You could use a timer for the plug to only turn on during certain hours of the day like they use for Christmas lights.
Hope this helps.
Sincerely,
Michael Scott
Jul 15, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
97 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
