Question about Hitachi 53UDX10B 53" Rear Projection Television
The power does not want to stay on.
Sometimes it will be on than shut off,and will not stay on after that. The power light comes on than off.
  • 616 Answers
TV needs major service, convergence and also the power supply expect to spend around $350.
Posted on May 02, 2010
Reduce engine power intermittent
Run a diagnostic test to see what codes come up and go from there.
Oct 04, 2014 | 2002 GMC Envoy
UNIT WILL SHUT ITSELF OFF WHEN IN USE SOMETIMES AFTER 10 MINS SOMETIMES TURN BACK ON AND IT WORKS AGAIN SOMETIMES WON'T COME BACK UP FOR A COUPLE OF HOURS
I suspect that the power supply is not making a proper connection and comes loose in the socket, the gps unit then is forced to use battery power but since the battery is not fully charged yet when the battery power is to low the unit shuts down and will stay down till enough of a charge or the power supply gets bumped and makes a solid connection again.
Jun 11, 2010 | Garmin nuvi 260W GPS Receiver
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Panasonic TH50PX85U power shuts off and won't come on.
power board failure, common in this model, replace power pcb then check VS and VA voltage could be X or Y driver causing power pcb to fail.
Aug 09, 2009 | Televison & Video
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
I have a 5 year old Dell Dimension 8300. Lately I have been having problems getting it to come on and stay on. Once running, it stays running great. Today it wont stay on. I hit the power and sometimes it...
It is likely your power supply is failing. When you press your power button a signal goes through the motherboard to the power supply, then the PS comes on. I would try a replacement power supply first, you can get a used one for less than $20.
Dec 31, 2008 | Computers & Internet
Power problem that I had last night - nothing works, any more suggestions
Hi again,
What might look as tight might not really be. Have you re-soldered most of the major solder joints/connections?
Jun 14, 2008 | Mitsubishi WS-65613 65" Rear Projection...
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV will not stay on
T701 sometimes cause this problem, more info ctechnicians.com
Dec 01, 2007 | Hitachi 61SWX12B 61" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
