Question about Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
How do you remove a Pac Fab Dynamo Impeller - Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: need to disassemble pentair dynamo pump to replace
Remove the cover from the back of the motor and lock the shaft from turning. Then spin off the impeller.
Posted on Jun 13, 2009
MOTORWIZJ
  • 1340 Answers
SOURCE: how do i remove the impeller from a dynamo pool
WITH LOTS OF LUCK . THEY SCREW OFF(OFF TO THE LEFT LOOKING AT THE IMPELLER SO COUNTER CLOCKWISE ) VICE GRIP OR SCREW DRIVER ON SHAFT TO HOLD IT, THING IS IF THE SHAFT IS RUSTY YOU HAVE A REAL GOOD CHANCE OF BREAKING IT AND IMPELLERS CAN BE HARD TO FIND.. THE SEAL SHOULD BE # 1000 FOR THAT PUMP... BEST OF LUCK.. J
Posted on May 25, 2010
  • 990 Answers
SOURCE: how do you pull the
After you have the pump broken down. Check for a screw in the center of the impeller. If it has one then you will need to remove it. This will be a left handed screw. If that is done then you will need to remove the back of the motor or the small center plate on the back. Then the shaft will accept a wrench to hold it with. Then you should be able to unscrew the impeller with water pump pliers or a large basin wrench. The brass threads on the impeller will kind of stick to the steel of the shaft so it is just a matter of breaking it free, then it will spin easily.
I usually put a screwdriver in the left side of the impeller and give it a sharp smack downward with a hammer.
There are two methods, good luck.
Posted on Sep 28, 2010
Is there a step-by-step how to change the sand in a pac fab super flow sand filter model pf35.
Try Googling (pac fab)(pf35)(manual) without parens for instructions.
May 19, 2017 | Pool & Spa
Pac fab sp710 filter control (old)
yes new spider gasket careful you might have to glue it in
Sep 23, 2013 | Pentair Pac-Fab 2" DE Filter Multiport...
I replaced a spider gasket on my PAC FAB 2# Multiport valve and when I put it back together the sequence is off. Filter mark is actually the waste port and waste is actually the Filter port.... how do you...
There should be a screw hole in the valve lid that has a flat edge on one side (outside edge). The valve body has a matching flat edge that aligns with it.
In the event the handle was removed from the lid and diverter to replace the diverter o-rings it is not uncommon for people to put the handle back on the diverter 180 degrees of where it should be. The pointer on the handle should be aligned above the open port of the diverter. This is true of all multiport valves except the Hayward four way valve.
Dec 06, 2012 | Pentair Pac-Fab 2" DE Filter Multiport...
I have a Pentair 2.0 pump that I am trying to remove from the impellar. The shaft turns allowing me to turn the pump part itself but I can not pull it loose from the rest of the housing. How exactly do I...
The impeller is threaded onto the motor shaft. On 2hp motors and above, there is usually a screw with reverse threads to help secure impeller to shaft. To remove impeller, first remove screw(reverse threads) Next, remove back cover off motor. The shaft either has a slot for a screwdriver or flats for a wrench. Hold shaft and unscrew impeller.
Aug 21, 2011 | Pentair One - Speed 1hp 115v Dynamo Pump...
The plastic where you screw the clear plastic lid on top broke on one side so the lid does't clamp down. Is there a way to repair this or replace just the tub part without buying a whole new pump? The...
PAC-FAB / Pentair Dynamo pool pump parts, Discount parts for PAC-FAB Dynamo pumps
This site shows a separate part for the strainer body, but I'm not sure it is separate.
Call them with your model number and they can tell you if it unscrews and sell you the repair part that you need.
Worse case, you might have to see if you can remove the entire pump casing and purchase that.
Gary
Feb 26, 2011 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
My pressure gauge is reading 0 when the pump is on. I have the pool water level good and filled the pump tank before turning on. I have used this unit 11 yrs now and 2 yrs ago housing front was replaced....
1. Make sure multi-port valve if on "filter" (gotta start with the easy answers)
2. Remove the V-clamp holding the pump housing together and start inspection.
3. remove diffuser to gain access to the impeller.
4. check impeller for clogs (very common if around pine trees)
5. If impeller in free of debris, inspect housing o-ring, diffuser o-ring, drain plug o-ring, and shaft seal (if any one of these parts as failed, this pump will not prime and the filter will have no pressure)
6. If all these things check out, then it is possible you have a suction side plumbing clog. (is the skimmer and main drain protected by screens? if so, a clog is very unlikely)
Note: the most common cause of a loss of "prime" on a pump is a failed shaft seal. It is cheap and easy to replce.
You will not want to remove the impeller or do any serious work on this pump unless you have replacement o-rings for the internals. New o-rings and seals is what allows these pumps to work properly.
Hope this helps
If this post helped you, please take the time to vote positively for me on this site.
thanks,
adam
Need more help? adamh@newconceptchem.com
Oct 28, 2010 | Pentair PAC-FAB CHALLENGER THREADED FRONT...
How do you pull the impeller off of the shaft for a Dynamo 1-1/2 sn 1-22-EO3?
Sep 27, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
How do i remove the impeller from a dynamo pool pump ?
May 25, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1HP -
Dynamo ABOVEGROUND POOL PUMP - 3/4HP - Logo
172 people viewed this question
Top Dynamo Pool & Spa Experts
Jay Finke
Jay Finke
Gil Shultz
Bosse Photos
Are you a Dynamo Pool and Spa Expert? Answer questions, earn points and help others
