Question about Dynex 32 in. LCD Flat-Panel HDTV
How do i get back to the initial set up screen i set it on antenna and have cable
  • 178 Answers
Dynex has too many different kind of on screen display menus. I got one here is Menu à Setup à Tuning Band à Cable/Air (you can select Cable) à Auto Ch Search.
Hopefully it solved your problem.
Posted on May 02, 2010
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen...
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Oct 19, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My Panasonic TC-32LX700 has decided it doesn't recognize any channels. No matter the station, the screen reads "Channel not available." It is hooked up to an antenna, not cable. I unplugged it and then...
If you searched for active channels and got no results, the antenna may not be adequate or may not be properly oriented. I have to use an amplified antenna even though I am located in a major metropolitan area
Oct 19, 2013 | Panasonic TC-32LX700 Television
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
I have a Sansuni 19"
Go to the menu of the unit.They are usually indicated on the remote it came with.Then locate the "input" tab.On the remote you can see it on the left hand side on the cirlcular control .Press it to setup your TV preference.Once you get to the input tab click it till you see a drop down menu locate the "TV" and see if it has a choice tab for antena or cable. Some have an arrow back and forward,some have up or down depends upon the brand.And with that chose "antenna" and do a channel setup before you exit.Start the channel setup on Channel 2 or else it will start counting and detecting (like 25 and up )you don't wanna miss the lower channels too.
Dec 15, 2010 | Televison & Video
Initial setup on Bravia 26" won't come up
Try resetting the TV to the original factory settings. After resetting the TV to the original factory settings, you can get the initial setup screen to select Antenna. Make sure that the cable from the Antenna is connected to the TV.
Follow the steps given below to reset the TV to the original factory settings:
(i) Turn ON the TV.
(ii) While holding down the Up arrow button on the Remote control supplied with the TV, press the Power button on the TV set. The TV will turn itself off then back ON again.
(iii)Next, release the Up arrow.
Sep 08, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Initial hdmi tv, no signal received
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Jun 22, 2009 | Initial Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
131 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
