Dynex pdp42 will not power up... i need to unplug from wall let sit for 15 mins and tv will then power on...
  • 178 Answers
It may have something wrong on power supply, usually you can see the capacitors pop up, if it is, replace it.
Knowledge obtain from: Repair experience on same symptom.
Posted on May 02, 2010
TV will not turn on, red light flashes dynex 22l150a11
I would try to power cycle the TV by unplugging it from the wall & leaving it unplugged for about a minute. Then plug it back in, power it on & restore back to default settings.
Sep 19, 2013 | Dynex 19in Tv/dvd / 720p / 60hz / Lcd Hdtv
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
Our Dynex dx l40 10a will not turn on. red light on front is on and the speakers are making a pulsing buzz noise. when we slightly jiggle the area that the power cord plugs into it turns off and on...
Turn the TV off, unplug it from the wall. Hold down the power button on the TV for about 20 seconds. Reconnect it and try to turn the TV on again. If the problem persists the TV is in need of some service by an authorized service center if under warranty. If not, look around for someone that can take a look at it in your area.
May 29, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Looking for Comcast remote codes for Dynex DX-PDP42-09. Would like to be able to change tv inputs with remote.I have the comcast remote that requires 5 digit codes.
google the name of your remote say for example need codes for philips remote it should give you plenty of them find your remote in the selections and get the code from it and how to put them in simple really and it will also say if the codes do not work it will give you a way to do a code search on your remote for it to work this is free no cost ive done it plenty of times
Feb 25, 2010 | Televison & Video
Dynex dx-pdp42-09 screen went black; won't turn on or off
dont really know,would you be interested in selling it lik that?
Feb 08, 2010 | Televison & Video
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Apr 09, 2008 | Nintendo Wii Console
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
