Question about HTC FUZE Smartphone
Often I don't see my contacts and the Sync Center
Often I don't see my contacts in my HTC Fuze and the Sync Center marks error.
How do I fix that?
  • 1 more comment
  • simonroch May 02, 2010
    I followed the procedure till the message PLEASE WAIT appeared but then it says: Error. Connection to update server was not available (Although I have a Wi-Fi Home Network I can't connect my cel to Internet).
    Is it possible to chat with you?
    I haven't received any response. Your web page said that we could contact by mail or chatting.
    I asked you if we coul chat. Can you answer me please?
    One hour ago I send to Pabloloco that his solution wasn't working and that I wanted to chat (option that was included to buy the assistance).I didn't get a response from Pabloloco.
    If we can't chat I will cancell my payment.
  • 713 Answers
Hi,i think you should put off the phone, take the battery out if possible,then insert the battery after 5mins,turn on the phone,and the problem is solved
If the problem remains,i think you should reset the phone to restore the factory settings,this should solve the problem as well,
if after trying the solutions above and the problem persists,it means the phone's firmware has to be flashed,that's the final solution.
Thanks and take care
Posted on May 03, 2010
  • 2,335 Answers
May I recommend you make sure Win Mobile is up to date by running Windows Update:
To set up Windows Update
The first time you run Windows Update, you need to set up how you want Windows Update to check for patches on the Microsoft web site.
1. On the Home screen, slide to the Settings tab and then tap All Settings.
2. On the System tab, tap Windows Update.
3. On the Update Setup screen, tap Next.
4. Choose how you want to check for updates, Manual or Automatic, then tap Next.
Note If you select Automatic, you will be asked if you want to use your current data plan to check for updates. Select or clear the Use my data plan to check for and download updates check box and tap Next.
5. Tap Finish.
To check for updates
3. Tap Check Now.
Note Windows Mobile® updates
I hope that helps.
__________________________________________
HTC Fuze Manual Download
Posted on May 02, 2010
  • Paul Sager
    Paul Sager May 02, 2010
    Thank you for requesting a chat. I would be pleased to chat with you.
    At Fixya we are only able to post or chat with one client at a time & I am more or less constantly with someone. I have just received your comments now, between clients.
    I have another solution for you, which I was going to suggest if the Windows Update didn't solve your problem, but I will go ahead and lay it out for you now.
    I recommend you update / replace the firmware / system software of your cell phone.
    I more or less specialize in firmware here, and find that corrupt firmware in phones, cameras, gps, mp3 players etc are the cause of almost all of their respective problems & thus reflashing fixes these problems almost every time.
    I would like to provide you with the correct firmware for your cell phone directly, however I would need to know your carrier / service provider, since each carrier uses custom firmware for their network.
    If you have AT&T service, please follow this link below to download your firmware.
    AT&T Firmware for HTC FUZE
    You will need to enter the serial number of your phone to start the download.
    If you prefer, you may feel free to post me your phones serial number & I will download it, confirm installation instructions and make it available to you with any relevant tips.
    I will check for your comment between clients.
    I hope that helps.
Htc sync wont sync phone comes up with error 1001
Hi @fmarcoux260496. I have some troubleshooting steps for you that may get HTC Sync working again!
On your PC, go to Control Panel and click "Add and Remove programs" in Windows 7 and Windows Vista or "Programs and Features" in Windows XP. Double click HTC Sync and choose "Repair."
If Repair does not work and you still get the error, reinstall HTC Sync. To do this, click on "HTC Sync" and then click "Change" or "Change/Remove" and follow the on-screen instructions. Do this for "HTC BMP USB Driver," "HTC Driver Installer" and "Adobe Air" as well. Once that's done, go to http://www.htc.com/ca/support/amaze4g-videotron/downloads/ and download and install HTC Sync. It is under the heading, "HTC SYNC 3.0.5579 FOR HTC AMAZETM 4G ' 15.12.2011". Complete instructions can be found by clicking "More." This will also install the newest HTC drivers and the newest compatible version of Adobe Air.
After you've finished installing HTC Sync, connect your phone to your PC via USB. Select "HTC Sync" from the "Connect to PC" pop up on your phone, and the phone will search for and open HTC Sync!
If you're still seeing the error message, disconnect your phone and perform a soft reset, and then re-connect the phone to your computer. To do a soft reset, just turn the phone off and remove the battery for one minute, then re-insert it and turn the phone back on.
If you still experience problems, I recommend you contact my teammates in Customer Support. You can find their contact information at http://htc.com/support
Please check in and let us know how that helped!
Jun 01, 2012 | HTC Sensation 4G
Tip
Download HTC Fuze Cell Phone Manual
Have you misplaced your HTC Fuze Cell Phone Owners Manual?
Would you like a digital, searchable, pdf version of the HTC Fuze Cell Phone Users Guide?
Follow this link (& click FREE) to download a pdf version of the HTC Fuze Cell Phone manual.
I hope that helps.
_____________________________________________
on May 02, 2010 | Cell Phones
Tip
I hope that helps.
on May 02, 2010 | HTC FUZE Smartphone
How to copy htc3300i contacts to pc/ samsung monte
1.Download HTC Sync 2.0.40 and install 2.Connect your HTC and PC 3.Tab connection setting in HTC Sync display menu (when you connect to PC Sync menu will automatically display) 4.Tab contacts.All the contacts in your handset copy to PC.
Mar 06, 2011 | HTC P3300 Smartphone
How do i sync music to my htc freestyle phone to my laptop?
Thanks for visiting FixYa!
Your HTC Freestyle uses the Brew operating System.
As such, the HTC Sync program for Brew will only synchronize Outlook contacts and calendar or Outlook Express contacts between your computer and your phone.
The sync software is pretty basic but does the job. If you want to sync music and media with the device then this won't do that for you. Instead you'll have to sync media to the storage card.
The Freestyle comes with a Music application that gives you the ability to play music that's on your microSD card. To load music on your microSD card: Connect your device to your PC via the supplied microUSB cable. Select Disk Drive from the popup menu. Once your device is connected, it will be listed as Removable Disk Drive under My Computer (Click Start > My Computer) and open it. From there, you can simply drag and drop the music files onto your device's microSD card.
If you wish to download the HTC Sync program, click on the link (below). At the HTC support page, READ the instructions, then scroll to the bottom of the page - click on the little blue arrow (under Download) - and select HTC Sync for Brew.
Click here:
http://www.htc.com/europe/SupportViewNews.aspx?dl_id=934&news_id=632
Feb 23, 2011 | HTC Cell Phones
Its froze on a screen iv never seen...
it means the software has corrupted ....go to www.htc.com and select the fuze and the rom should be there dowload it to your pc ..remove your sim card and memory card ...connect to active sync and run the .ruu file(the file you downloaded from HTC ) the onscreen instructions are easy to follow ......make sure phone is atleast 50 % charged
May 24, 2010 | HTC FUZE Smartphone
HOw do you download contacts from HTC Touch Viva Cell phone from sprint phone to window vista?
you can interface your HTC with outlook using active sync or windows mobile device center. once interfaced you can synchronise your contacts.
Sep 25, 2009 | HTC Touch Viva Cell Phone
Cant sync my contacts
Hi, U cant sync up means wat? Does it throw any error? One tip: if u have your email account on ur laptop configured for both outlook express and mirosoft office outlook be careful..,cos all the contacts go to microsoft office office outlook :)
Mar 25, 2008 | HTC Touch P3450 Smartphone
HTC FUZE Smartphone Logo
35 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
