Question about Refrigerators
On humid days water puddles in the bottom of the frig.
On humid days water puddles in the bottom of the refrigerator. The ice maker is shut off so I don't know where the water is coming from. Any ideas?
There is an open drain that runs horizontaly across the back inside of frig that leads to a vertical drain on the left hand side. This drains to drain pan underneath the frig and is accessable from the front panel on outside bottom of frig. See if there is water collecting in the horizontal drain. This happens if vertical drain is blocked up and causes the horizontal drain to overflow to the bottom of the frig. This caused in my case a rotting and mildewing of the maple wood on the side and front of frig. No mention of drain pan in manual. If you get this far you should remove, clean and replce drain pan.
Posted on Jun 03, 2012
  • 555 Answers
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
Posted on May 03, 2010
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Went on vacation and shut water off in house. Came back from vacation and frig. stop making ice. What do I do?
fill tube is probably clogged with ice you will have to melt the ice in the tube that goes thru the back wall to the ice maker, if you shut off the water turn off the im too
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
No water entering Ice Maker. Noticed the problem when water was dripping out of the fitting on the back of fridge that goes to icemaker. Also the icemaker is not making ice. Tightened screws but...
Ok i would disconnect the water hose to the frig, turn off the water. first
then put the end of the hose, in a bucket..see if you get a good flow of water, if you do..2nd your going to have to buy a new fitting..for the copper or plastic hose. then lets go from their
Dec 18, 2010 | Kenmore 77309 Bottom Freezer French Door...
Ice maker not working
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
Water leaks from freezer when door is shut. Not everyday, but small puddles every 2-3 days
threre are plastic tubes in back , sometimes get clogged with ice or other matter, these pull out and then you can clear them
Mar 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water running under frig.
have you tried turning the water off(if you have a tap/faucet behind unit).....
Feb 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
Water =underneath= the refrigerator
Check you door gaskets for gaps or cracks that would allow air to get in the frig. Look for a bad water valve or ice maker head. If your ice maker is faulty it will instead of filling for 7 seconds it will fill the ice mold for 30 seconds. Put the arm up to stop ice production and wait awhile. Then lower the arm and observe the harvest cycle. The water valve should be energized for 7.5 seconds very near the end of harvest cycle. Just a GUESS
Jul 17, 2009 | Frigidaire FRT18B4A Top Freezer...
Ice maker output very low volume
Hi!!! check your filling tube line going into the icemaker its a white tube that gives water to the icemaker.It might be plugg of ice..get a hai dryer and aim it for 30 minutes good luck..
Jan 05, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
