Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have cobwebs / dust inside my bigscreen and when a scene that turns the picture all white, you can really see the cobwebs on the inside/backside of the screen. Took the outer plexi-glass off and cleaned it, but it appears its inside / behind the projection screen.....how do i get in there and get rid of the cobwebs?
  • 616 Answers
Screws behind the bezel. easy to remove, a pain to re-install, best to have a tv shop do it
Posted on May 02, 2010
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
My polaroid iS2132 won't change settings when I turn the mode dial/Can't set the intelligent scene mode.
When you put the Mode dail to the SCN mode, It will enter the last used Scene mode. THEN press the MENU button to select other scene mode.
Don't turn any dail. Use the navigation controls left and right from the OK button, to move through the section. Press OK button to save and activate the selected scene mode.
Success
Nov 17, 2013 | Polaroid IS2132-BLACK 16MP 21X Zoom...
Cobwebs proscan ps56700 inside screen
It can be done from the front but from the rear is actually more easy and safe--removing front screen and frame entails some danger of damage to the screens.
I have over many years of outside/home service calls encountered this.
As a outside technician I want the quickest and safest way to do this.
With set unplugged simply remove rear cover:
Use a swiffer type duster to reach up and inside and gently get all the webs out(do not use force when against the inside of the screens) and if the handle is long enough you will be able to remove all of the webs.
Also when doing this you will see with cover off 3 large black lens at the top of the chassis above the circuit boards.
They are the light source for your picture--clean them with a lens cloth or a paper towel with Glass cleaner sprayed on it---Do not attempt to clean the mirror in the rear as it is a film material and is easily scratched.
If the lens were dusty/dirty and then cleaned the picture will be brighter and sharper looking----that should be done about one time a year.
If you have questions make a comment here on this page(make a comment button).
Apr 21, 2012 | Proscan PS56700 56" Rear Projection...
Have a Mitsubishi Model WD-62528. Picture is dull and colors anr not viberant. What can I do to get the great picture I had. Changed light about 4 months ago
I notice the same thing with my 62" after several years -- the problem was dust on the inside if the screen. Take it off (have someone help you - it's big and bulky) and carefully clean the dust and also in my case cobwebs from inside the encluse - this made a huge difference for me in picture brightness and clarity.
Nov 25, 2011 | Mitsubishi Televison & Video
CAN YOU PLEASE EXPLAIN TO TO ME WHAT IS EV COMPENSATION AND HOW DOES IT WORK
EV compensation is "Exposure Value compensation". The camera contains an exposure meter which determines how much light is on the scene and sets the exposure appropriately. However, this meter does not know WHAT you're taking a picture of, nor does it know what effect you're going for. The best it can do is to assume you're taking a picture of an "average" scene and want it to be of "average" brightness. It does this by assuming the scene is "middle gray," halfway between black and white. Most of the time this works fine, because most scenes are, well, average.
However, this is not always the case. Suppose you're taking a picture of a white dog playing in the snow. Almost everything in the scene is bright white, but the camera doesn't know that. It tries to make the scene middle gray, and the result is that you get a gray dog playing in gray snow.
On the other hand, suppose you're taking a picture of a black cat sleeping on the hood of a black car. Here everything is black, but the camera doesn't know it. It tries to make an average scene, resulting in a gray cat sleeping on a gray car.
EV compensation allows you to override the camera's exposure setting. In the first example, you'd want to add two or three stops (positive EV compensation) to force the camera to render the dog and snow as white instead of gray. In the second example, you'd want to subtract a stop or two (negative EV compensation) to render the cat black instead of gray.
How much EV compensation is correct? Well, that depends on the scene. With a digital camera, you can look at the picture and see whether the dog looks white or the cat looks black. Film photographers take lots of shot, using various levels of EV compensation, so that one of them would come out right.
Mar 19, 2011 | DXG Technology DXG-505V Digital Camera
My Hitachi 65F59 has a very low green level. If I set the tint all the way on Green, I see some small amounts of green spots on scenes, but scenes which should be completely green are mostly a beige ugly...
SUGGESTIONS TO RESOLVE WHERE THE PROBLEM IS:
1. GO TO A BLACK AND WHITE CHANNEL OR PROGRAM AND TURN THE COLOR IN THE CUSTOMER MENU ALL THE WAY DOWN.
IS THE PICTURE BLACK AND WHITE OR REDDISH ETC?
iF THIS IS THE CASE I CAN TELL YOU HOW TO ADJUST THE SET MANUALLY--NOT WITH THE REMOTE BUT IN A DIFFERENT WAY.
I am here to help people and if this helps you rate this solution as very helpful as I do this here for free.
Make the check to see if you have a BW picture or not, if not respond and I will tell you how to adjust---it will take about ten minutes to do it.
REGARDS, SD TECH
Aug 13, 2010 | Hitachi 65F59A Television
My RCA DLP HDTV shows ''Cobwebs''
It is in the top half of the set. You will have to remove the top back cover to clean it.
Jul 09, 2009 | Televison & Video
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
White noise
Unplug the set for 2 minutes and then trying again.
Jul 31, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
489 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
