Question about Air Tools & Compressors
Our craftsman air compressor 7 gallon has just quit working
  • 374 Answers
Hi there;
there are several reason we can consider why your compressor quit working, this due to mechanical or electrical function.trial should be done.1st trial switch off from the breaker your compressor disconnect pressure switch,connect the electrical circuit w/o the pressure swtich.direct connction the run the compressor if run, replace pressure switch.put back connection.if on 1st trial does not run the motor compressor the problem is on the motor
check the connection specially the over load protection,reset and run again.if still not runnign pull out the motor and have it repair on electric motor repair service center.then the motor is good put it back.have a nice day fix my rate thanks a lot.
Posted on May 08, 2010
Bought new 7 gallon 1HP horizontal craftsman compressor. Used first day worked great . Second day plug it up hit on switch and all it does is click when you cut it on and make a humming sound
does it have oil? take it back for a replaement. pull the belt off and see if the motor is still good. turn the pump by hand to check for free turning.
Apr 22, 2015 | Craftsman Air Tools & Compressors
I have a 3 gallon 1HP Craftsman air compressor has worked fine for years but now it won't build air pressure over 20lbs. Any suggestions?
Make sure there are no air leaks first.
Your pressure valve may need resetting or replaced as it could not be working. Your compressor might be wore out.
Is there a gizmo that you can turn to set pressure. if so that might not be working if you have tried to set it.
Sep 09, 2014 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a Craftsman 3 gallon air compressor. When
Is your air pressure regulator set very low? Try adjusting it to a higher pressure
Mar 08, 2010 | Water Heaters
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
We have a 30 gallon; 6HP Craftsman Compressor; Single cylinder/oil free; 120 volt, 15 amp compressor. Mod. #: 919. 167311; Serial #: 2216185983. It has quit working, do you know what may be the issue and...
DOES IT RUN AND NOT MAKE AIR? BUZZ OR MAKE ANY NOISES AT ALL? DO YOU HAVE POWER TO IT? HAS IT BEEN IN THIS LOCATION AND WORKING FINE TILL NOW? NEED MORE INFO. JODY
Jun 29, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
139 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
