Question about Olympus Photography
Light meter not working on olympus 35rc can it be fixed
  • 55 Answers
Three places to look for are:
1)Battery terminals and the wire from the battery terminal. Check for battery corrosion. 2) CdS meter cells is bad 3) Galvanometer is bad.
The camera can be repaired but you will need a donor parts camera.
Posted on Jun 17, 2010
Testimonial: "Thenks I'll have a look and see what it looks like"
    Problem Solver:
  • 13 Answers
Also, switch that turns meter ON may be dirty or corroded. Switch is located under shutter plate. John
Posted on Oct 16, 2010
Olympus VR-310 wont turn on?
Is there sufficiand battery power ? in the battery? is the switch working try a ohm meter on it to see if the switch works that will give you a idea how the battry is.
Dec 18, 2014 | Olympus Cameras
Problem useing the zoom on Olympus 70-300mm Lense
No, but it appears that there is a bad tooth or something in the gear mechanism of the lens. Internal issue, hopefully over time it will "go away." Cross fingers and hope it does not get any worse. I would carefully shake the heck out of it to possibly dislodge what ever it is.
Sep 03, 2017 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
I Have olympus fe230 7.1 mp digicam it does not have a power even i bought a new battery pack.
You say you bought a new battery pack but have you actually checked it with a meter to make sure it has sufficient power?
I picked up an fe-230 used that had no batteries and bought a set of 2 batteries and a charger off ebay. According to the light on the charger the batteries are charged and ready. Only they aren't according to my meter. The el cheapo fleabay charger is no good.
So assume nothing and check your battery with a meter and go from there.
Apr 29, 2011 | Olympus FE-230 Digital Camera
My Olympus OM-1 light meter is not working. Simple fix or off to repair shop?
Simple: Negative polarity wire isolated contact spill px13 batt.. Negative contact spring, is it greenish? unscrew 4 screw bottom cover and also two of batt chamber , pull out carefull not to break the brown wire. Is the wire unsolded ? If yes ,clean with amoniac de batt. cham. and after rinse in water , sec and resolder the wire , assembly.
Not simple: Other cause meter coil bad.
Feb 15, 2011 | Cameras
Olympus u770 sw 7.1 No power, battery fully charged, lens cover is open. No lights no screen nothing. Camera has been perfect for almost 4 years just shut down whilst being used hence lens cover open. Any...
Hi
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
Hope this helps
David
Jan 13, 2011 | Olympus Stylus 770 SW Digital Camera
Had the camera for 13 months. I suspect the light meter is busted. Photos indoors are OK, outdoors or in strong light are over exposed with horizontal lines through the photo. Quoted $160 to repair with...
Just put some part of a finger or two over the lens to cut down the light outdoors. Your shutter diaphrame is not working, but keep on using the camera, it might free up.
Dec 21, 2010 | Olympus FE-340 Digital Camera
I bought an Olympus FE3010 yesterday and the battery did not charge. The light on the recharge pack stayed on for only two minutes. I received a replacement from the retailer, and I'm still having the...
I'm thinking its a lemon. We also have purchased an Olympus fe-3010 took it back and received another and have the same problem It won't turn on we checked the battery using a dc volt meter and the battery was fully charged.We have decided back to the retailer it goes. Good luck to you =)
Jul 11, 2009 | Olympus FE3010 Digital Camera
Camera stopped operating
Well I know what the review says about underwater to five meters http://www.ephotozine.com/article/Olympus-Mju-725SW
but I would take it with a pinch of salt frankly.
You could get onto Olympus and tell them you know- 'You said I could take it under water - now it wont work' - They may replace it
Jul 12, 2008 | Olympus Mju 725 SW Digital Camera
Lighting problem with Olympus E 500
It sounds like it may be a broken shutter.
Mar 16, 2008 | Olympus EVOLT E-500 Digital Camera
Metering modes
There are three metering modes: Digital ESP, Center Weighted Averaging and Spot. DIGITAL ESP - The camera meters and calculates the light levels or light level differences in the center and other areas of the image separately. CENTER WEIGHTED AVERAGING - The metering mode provides the average metering between the subject and the background lighting, placing more weight on the subject at the center. SPOT - The camera meters a very small area around the center of the subject, defined by the spot metering area mark in the viewfinder.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Photography Logo
568 people viewed this question
Top Olympus Photography Experts
pontelemon
pontelemon
Steve
David Payne
David Payne
Are you an Olympus Photography Expert? Answer questions, earn points and help others
