Question about Princeton Digital VL1918 Monitor
Driver downloads I need the drivers for a VL1918 & for some reason I can't connect to your server...can you email it to me? If you can, I'm [email protected]
  • 55 Answers
Http://www.princetongraphics.com/site/support_drv.htm
NOTICE: Your monitor does not require any drivers to function. If you have problems changing resolutions, color depth, or refresh rates, Please consult your video card manufacturer for a video driver or support. Your system will not identify the monitor if video drivers is not installed properly.
You might want to check your video card drivers. Hope this helps.
Posted on Mar 25, 2008
SOURCE:
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
I have no sound on my Prinston VL1918 monitor now that I hooked it up to my new ASUS computer. Do I need to download a driver?
No sound driver is needed for the built-in monitor power speakers (just think of it as a Powered PC speakers built-into the monitor). Are your PC sound card and driver and setting OK? Try feeding the monitor with sound source from MP3 player to see if it works OK, To repair the amplifiers in the monitor will not be worth it since you can spend the same amount for a good set of Powered PC speakers instead with much better sounding.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Mar 11, 2011 | Princeton Digital VL1918 Monitor
Where can i download the driver for DP-301U
Print Server doesnt require driver. Connect the printer to the computer directly and check if it is printing. The drivers for the printer will be loaded and you will be able to print. Then connect the printer to Print server and you will be able to print. If it is still not printing, you have to create an LPR port for the printer driver
Aug 21, 2010 | D-Link DP 301U (DP-301U) Print Server
Need to download drivers for a princeton vl1918 HELP!
open the internet and open the link www.softwaredriverdownload.com/princeton_graphics_vl2018w_driver.html - United States and you can instantly download the drivers
Mar 28, 2010 | Princeton Digital VL1918 Monitor
LBP2900B DRIVER CD
CANON LBP2900B DriversHere is the driver for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7
Installation Procedure when Connecting USB Cable
Do not connect the USB cable until after you have loaded the downloaded files.
After all files have been loaded connect the USB cable to the back of the printer.
DRIVERS
Thanks & Regards
M. Nanda Kishore
Dec 29, 2009 | Canon LASER SHOT LBP-2900 Printer
Where can I download SUPERMICO 7043M8B Server Driver?
Here is the url from where you can download all your drivers
http://list.driverguide.com/list/company997/?t=1
get registered with an email id in www.driverguide.com (it's free) and download it
Dec 15, 2009 | SuperMicro Super Server 7043m8b
I have connected the audio cable from the computer to the monitor and there is no sound.. where can I find the driver?
Vista is usually pretty good at sourcing device drivers! Do you have your original Vista install CDs. It might help to have the Vista CD in the drive when you plug in the audio cable and see if the OS can find the appropriate device driver on the CD.
Otherwise is your system connected to the internet? If so Vista will also try to download appropriate device drivers from the Net.
Failing that you will need to manually source the driver from the web. I find that Google is the best resource for finding device drivers. If you right click on the device with the yellow "!" in device manager and select "Properties". Then click on the Details tab and check out the Hardware Ids. Often as not putting these into Google will help you identify the device, and give you an idea of where to get the appropriate device driver.
Dec 10, 2009 | Princeton Digital VL1918 Monitor
I want to connect the print server ESI9132079.i need drivers for this print server.
hi,
Download and read the manual of this print server.
http://silexamerica.com/us/products/pdf/xtnd/dx-sx.pdf
You only need the actual printer drivers not the print server driver (there is no such thing for print server drivers). Once you connect to network and to Print server, you should be able to see what brand printer is connected to server such as HP, Epson, Fujixerox, Samsung, etc.
Hope this helps
Cheers
Shafie
May 08, 2009 | Troy ExtendNet SX Print Server
Vl1918 backlight replacement
this is not a driver issue. There is a hardware problem. You will have to replace the lights, or purchase a new monitor.
Please rate me.
Thanks and good luck, let me know how it turns out.
Feb 02, 2009 | Princeton Digital VL1918 Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
621 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
