Question about Ovens
We have the smell of gas when the oven is pre-heating
When I am pre-heating the oven, we get a strong smell of gas in the kitchen. The oven is heating and the coils are on in the oven itself - but the smell doesnt go away until the oven gets pretty warm. Obviously it needs repair, but I would like to know what it might be so I don't get taken advantage of by a repairman. Thanks for your help!
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 02, 2010
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
We smell a stronge oder of gas while heating the oven. Also, it is taking along time to heat-up.
Check for leaks on pipes and fittings. Mix a small amount of washing up liquid and water make sure it is nice and frothy , put around 1 joint at a time (do not light any burners), if bubbles start to blow then this is where your leak is, but still check all remaining joints.
Jan 04, 2010 | Magic Chef 9122 Gas Single Oven
When I heat up the oven i get a strong smell of gas and it fills
Ok, your mixture is to rich at this time. you will need to access the gas pressure regulator and adjust the air to fuel mixture. add a bit more air and back off of the fuel a bit. this will correct this issue.
depending on the model, this may or may not be an option so, if you cant access the regulator and the burner assembly is not accessible as well, i recommend calling the local gas utility service tech to preform this adjustment. This rich mixture is very dangerous for you and your family and i suggest that this be corrected asap for you safety.
Please rate and god bless:)
May 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Propane kitchen-oven ''whoofs''
Propane burns very dirty,I bet the burner and pilot are clogged with soot.In techinical terms the sound your hearing is blowback.If you check the burner/pilot you will likley see black soot,remove them and clean with soap and water.
Mar 16, 2009 | Ovens
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Ovens Logo
211 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
