Question about Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ)
Model gs6shaxlq03 icemaker red light flashing
Model gs6shaxlq03 icemaker red light flashing not making ice
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
fridgetech
  • 473 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
Red light flashing on ice control panel in freezer section of my Whirlpool gold GS6NHAXVT02. I have the setting on ''on''.
The red light is supposed to flash. The number and frequency of flashes is a diagnostic tool we use to determine what is wrong if the icemaker is not working. If your icemaker is not working, count how many flashes before it rests, and let us know. Good Luck, Appliance Specialists
Jan 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not make ice. everything in installed properly. unit is 7 years old. red light flashes twice, then pauses and flashes twice again.
in the door ice storage. this is complicated. might check at the bottom of ref. there is a removable toe panel and on the back of the toe panel usually there is wiring diagram & mini manual to help diagnose icemaker problems.
Jan 03, 2010 | KitchenAid KSSS36QK Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Whirlpool icemaker not making ice
optics would not gon bad from frozen water, strictly a computer watching ice level in ice bucket. it should however be lit blinking at least, if it set ot on positoin and no indicator light is on at all sounds like a bad emiiter/ reciever.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Dec 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ) Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
