Question about Dryers
Drum makes thunking noise even when level - Dryers
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 03, 2010
Big Thunk when Frigidarie Front Loading washing machine started the final spin cycle, then at the end of the cycle soft screeching sound when drum is moving back and forth, any thoughts? amshap50@gmai
does not sound good. if you can remove a cover on front bottom or on the back you may find a broken shock, or counter weight, either would need replacing before running again
Jan 08, 2012 | Washing Machines
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
My maytag dryer model lde5914acm makes a 'ker-thunk' noise as the drum rotates. It makes the noise approximately every rotation of the drum. It has been getting progressively worse over the last 10 loads....
Dave,
First off I would suggest a visual inspection of the inside of the drum. Also try to observe it while it is running to see if the drum is off balance. That can happen if a large or awkward load is put in the dryer. If that doesn't yield any results then it may be time to check things out inside the machine. I would strongly recommend disconnecting power from the unit, especially if you are unsure of what you are doing. It just isn't worth the risk. Look for anything that seems wrong or out of place. Aside from that, I can't be of too much help without being there.
Dec 16, 2009 | Maytag Dryers
The drum makes a thunking noise as it spins
Something Is Stuck or you need a roller bearing.
Oct 10, 2009 | GE Dryers
97 dodge intrepid. motor is thunking when its running and in gear
Sounds like you already know what is wrong with it. It most likely needs a motor, or a rebuild.
May 28, 2009 | 1997 Dodge Intrepid
2001 Pontiac Aztek Rear Psg Tire Thunking Sound
just a thought but is it a new drum ? it could be defective (out of round) or are the shoes seated on the backing plate right or the emergence spreader bar in right way causing shoe to bindif not or shoes are on wrong if it has a primary and secondary shoes .And check to make sure lug nuts are secure and that the rim is not shifting on braking .that ii have seen lots of times
Feb 16, 2009 | 2001 Pontiac Aztek
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
