Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Freezer not working
Making noise and spatting black inside
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer not working - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 28, 2010
Candy CSC 1745WE fridge freezer just started making a noise like the cooling fan is catching on something.This noise stops when you put pressure on fridge or freezer doors. Any ideas, many thanks.
If the defrost is not working then ice could be forming inside the unit. If that's the case then it will get worse as more ice forms and the unit eventually wont cool or will cool very little. Sometimes a panel or the fan blade isn't adjusted right and it hits something making noises. In the case you would have to pull the covers off inside the freezer .
Sep 19, 2016 | Candy Refrigerators
Right Door is making loud popping noise
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My freezer is making a continual "creeking noise" that quits when I open the freezer drawer. Any ideas what the cause may be and how to make it quit?
I HAVE SEEN 3 THINGS DOING THIS. ONE IS THE BACK PANEL INSIDE THE FREEZER. IN WHICH I REMOVE THE PANEL AND ADD SOME MORE CUSHIONED TAPE. SECOND IS THE COILS UNDER THE REF. MAKING CONTACT WITH THE CAINET OR FLOOR. MOST COMMON IS THE EXPANSION AND CONTRACTION OF THE TUBING IN THE FREEZER WHICH CANNOT BE FIXED.
Apr 25, 2010 | Maytag 25.1 Cu. Ft. Bottom-Mount...
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
JennAir JFC2087HRS makes creaking noises like an old door or someone's stomach growling all day. Now noticed that ice maker not working. Suggestions on how to fix?
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Apr 01, 2010 | Jenn-Air JFC2087HRS Side by Side...
Refridgerator make a noise every 3 minutes
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
