Question about Kirby G4 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
  • 438 Answers
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
Posted on May 03, 2010
  • 52 Answers
I agree it is the fan
Posted on Jun 06, 2010
  • NITROJC Feb 21, 2011
    Hello People,
    Does the Green Light have anything to do with the Amount of suction ? Its already been said that when the light is off ... something is wrong; possible the roller, or belt isn't working properly.
    Lastly, what is it that activates the Green light ? Would weak, or very little suction cause the light to Go-OFF ??
    Please answer the question ... A.S.A.P.
    THANK-YOU, James.
  • Chris Jones
    Chris Jones Feb 21, 2011
    The green light is an indicator that alerts you to whether or not the roller brush is spinning. There's a magnet at thend of the beater bar, and when properly installed, and a good belt, this magnet when spinning causes the green light to come on. If the light is not coming on, this indicates either you have a broken belt, or the belt was not installed correctly, and is not on the pulley, or motor shaft. This means that your roller brush is not spinning, which will dramatically decrease the vacuums performance. Please check out the video and try installing a new belt, this should fix it. If it doesn't, a new roller brush assembly can be the only other problem. Thanks!
Kirby g4 how to switch from suction to blower
Remove bag from canister.
Attach hose to canister where the bag connects.
It can now be used as a blower.
Jan 26, 2011 | Kirby G4 Bagged Upright Vacuum
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
Nov 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G4 running very loud and smells hot.
were you put the belt on see if any thing is rubbing against shaft.it may have been the belt,replace the belt and clean out the bab and also the floor brush.
Jul 31, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby Suction and Blower Connector
Yes you can. The end of the hose that mates with the suction/blower is flexible. You can use a pair of needle nose pliers to compress the hose end and force it out of the suction/blower connector.
May 08, 2010 | Kirby G4 Bagged Upright Vacuum
I've owned my Kirby G4 for 15 years and never had to touch it for maintenance. Should I ever get it overhauled or tuned up?
Kirby recommends getting it serviced yearly but if you are mechanically inclined you can service it yourself. the biggest thing is cleaning and blowing all the dust out of the motor and inside compartment. also check your motor fan for chips nicks, and stress cracks around the center. Inspect the bearings and motor carbon brushes for wear and noise. and put some 3 in 1 oil on the top handle slide assy on top of the motor. do not disassemble this unit there are many way bearings inside and if its not reassembled just right it will throw off your self propelled unit
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 without suction
change your belt, if there is suction from the hose, and you cant see any blockages in the area where the brush roll is then you need to change the belt, even if it isnt broken. putting your hand over the nozzle to feel the suction is not the way to tell if it has suction.
Oct 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 plugged????
Take the bag off of the vacuum, remove the paper bag, clean out the bag tube then put back on. Make sure that the tube is broken, it is, replave it.
Dec 29, 2007 | Kirby G4 Bagged Upright Vacuum
My kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Nov 10, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
1,962 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
