Question about Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold, Oven
This last week, the door came OFF the oven when it was opened, one side hinge completely slid out of the oven... now the oven wont work at all... is there a fuse that needs to be checked or something that needs to be reset??
Can no one help with this problem??
Posted on Apr 05, 2008
Remove door on whirlpool stove or range
I'm not sure about Whirlpool but most doors have a little locking latch on the door hinge. Look carefully at the exposed hinge when open and see if there is something you could pry up with a screwdriver while someone supports the door. Then you lift the door away. Its all in the owners handbook if you have one. If not go to the manf website and see if you can download one.
Feb 23, 2015 | Whirlpool Gold GGG388LXS Stainless Steel...
Installation oven door
In order to reinstall the door you will need to extend the hinges out on both sides...You will notice a small hole at each hinge..Insert a nail in to each hole (one on each hinge)...Set the hinge so that the it is extended outward with nail in place...Once completed set the door back onto the oven with hinges inserted into slots in housing....Open the door as far as it will go...Remove the nails ..The door should now work properly..
Apr 20, 2010 | Whirlpool GS460 Gas Kitchen Range
The oven door does not close properly and stays open enough to keep the light on. Whirlpool Gold, Model GR399LX60
If it has a drop down door with hinge on either side, then only solution is to replace both door hinges, as the problem is usually due to weak door springs, and they are not adjustable.
Please rate my solution.
Feb 01, 2010 | Whirlpool Ovens
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
How to take off oven door
Open the oven door. Look at each hinge. There is a clip on the hinge that has to be opened for the door to come off the hinge.
The clip does not come off the hinge it only rotates backwards and forwards.
Nov 21, 2009 | Whirlpool RBS275PD Electric Single Oven
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
How do you install oven door on Beaumark Model 13340-1
Figured it our by myself - the 2 hinges (long and short have to be "hooked" together and then inserted into the oven hinge opening.
After I solved it found the solution is also posted on appliance repairs- how to remove and install oven door. It also posts pictures.
Jan 23, 2009 | Ovens
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 | Ovens
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool GR465LXLS Electric Kitchen Range Logo
100 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
