Question about Kingston flash memory card - 256 MB - MMCplus Graphic Card
I cannot remove the write protect setting on usb removable disk
  • 68 Answers
If it is a memory stick there will be a button like an on off....
If it is a flash drive you can go to its properties and change the property
Posted on May 02, 2010
My sandisk pen drive is write protected
Remove write protection from Sandisk pen drive with write protection removal software. Double-click on the WriteProtect value in the right-hand pane of Regedit.exe. Change the Value data from 1 to 0 and click OK to save the change. Close Regedit and restart your computer.
May 12, 2018 | SanDisk Computers & Internet
How can i unwriteprotect my 16gb sandisk flashdisk
Open up a command prompt as administrator
Type diskpart and press Enter
Type list disk, and you'll get a listing of all drives on your machine.
Type select disk # to select a disk. You can use the Size column to identify which one it is.
Type attributes disk clear readonly - change your USB's properties so that it is no longer read-only.
Feb 04, 2018 | SanDisk Computers & Internet
Write protection
Write protection means you can view the information stored in it but you can't write and transfer the information to it.
For removing the write protection follow the below mentioned steps:
1. Right click on the USB stick
2. Go to properties and uncheck the read only or write only protection option.
May 12, 2013 | EDGE Tech Corp Edge Diskgo Mini - Usb...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective.
Jun 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to remove write protection from sandisk cruzer flash drive
how do I remove write protection on my cruzer 2GB thumb drive
Feb 21, 2009 | Cameras
Computers & Internet Logo
124 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
