Bluetooth dongle i can send files from my mobile to the laptop but cant find how to send them from pc to phone, i have a bluetooth dongle on the laptop
    Scholar:
  • 47 Answers
  1. Go to the file you want to send to the phone
  2. Right click the file and select send to option
  3. Unde the sent to option select the bluetooth option
  4. Undet the bluetooth option select your mobile phone if it is listed or choose other if it is not listed
  5. Follow the process that pops up in the window until you send the data to your phone , make sure your bluetooth is activated on the phone and when it ask you to pair device you so perfectly
As an alternative method (though no a easy method)
  1. Move or copy the files you want to sent to the phone to the bluetooth exchange folder
  2. access your computer from the my devices option on your phone and choose the get it option to get the files coppied to your phone.
Posted on Mar 25, 2008
I want to connect my phone to my pc by bluetooth what do i do ?
Dear user,
If you have a desktop you need a Bluetooth dongle and required software installed in your PC, if you are using a laptop with Bluetooth then its good, all you need to do is switch bluetooth ON on both devices (keep them in visible mode)
send the required file from target device to destination device , accept all notifications as yes on both
if you want to use it for surfing on PC by making ur mobile as modem then install the motorola software from CD. and follow the instructions to connect Bluetooth.
May 04, 2011 | Motorola Mobility Defy Cell Phone
I can't Install Java Games i my Samsung A767 ...Its always Says "Unsported Files"
hi i think u might have directly copied the games to ur phone's memory card via data cable doing so may result in the phone saying unsupported files but since ur phone is java supported and the games will work for sure u can install the games via bluetooth enabled laptop or even u can use a bluetooth dongle to install the games in ur mobile.To install the games in ur mobile via the dongle follow these steps:-
1.first plug in the bluetooth dongle in ur system and ur PC will detect it,as soon as it detects the device go to the START menu PROGRAMS ->ACCESSORIES->COMMUNICATIONS->BLUETOOTH TRANSFER WIZARD and click on the ur system bluetooth wizard
2.switch on ur mobile bluetooth and search for any paired device u will receive a prompt message as soon as ur system detects the mobile and will ask u to enter the password type the same password which the system will generate and ur mobile will be paired u can then select a game file and send it in ur mobile from the PC via the dongle as soon as the file is copied u will receive a message in the mobile to install it type yes and there u go the game will be installed.
u can also try using another phone switch on the bluetooth device of the other phone and copy the file in the targeted phone via the bluetooth .was this useful to u if yes pls do rate my solution and u can also send ur views via the testimonials thanx fr visiting fixya
with warm regards - bonefirediv.
Apr 18, 2011 | Samsung Propel A767 Cell Phone
I have a bluetooth dongle. problem is i can only send files from my mobile phone (bluetooth enabled) to my pc and not vice versa. the bluetooth dongle (connected to my pc) can't search for other bluetooth...
You need to give more info, I'm afraid.
What type of phone do you have? What OS does it run? What kind of OS does your PC have? Did your adapter come with software? You say you can send files from your phone to your PC, but then you say that the PC doesn't the phone (?????!)
Since I don't have any clarification, here's some things you can try:
- Try shutting down and re-starting both your devices with the adapter still in. Try taking the adapater out, re-starting and then plugging the adapter in.
- Re-install or update the software for your adapter. If you decide to re-install, make sure you remove all th eold files completely. If it's plug and play, you can use device manager (assuming you have Windows) to find better software.
- Make sure your phone has the proper permissions set to receive files from your adapter. Since I do not know your phone model, try to google it.
- Try opening Bluetooth Devices in Control Panel. Click on Options and make sure you've enabled the PC to accept files from your mobile.
Bluetooth isn't two way automatic communication. Both devices that are using Bluetooth to communicate must individually have permissions set for the receiving of files from each device it connects to. You can send files all day long, but if the device youre sending to isnt set up to receive, it obviously won't work. Make sure you've enabled it in both the PC and the mobile.
Good luck.
Mar 21, 2011 | Computers & Internet
When i pair my samsung GT C5130 with my laptop then it ask for pass code to complete pairing process but i don't have pass code .plz assist me
How to Connect a Phone Using Bluetooth With a Laptop
By using Bluetooth technology, you can send files from your phone to your PC without the use of wires, SD cards or memory sticks. Many newer laptops have Bluetooth connectivity, but some models do not. You can make these laptops Bluetooth-enabled with the use of an external Bluetooth device called a Bluetooth dongle. This is a USB stick used to enable Bluetooth on your laptop, as long as it's plugged in.
Instructions
Pairing the Devices
Switch your laptop and cell phone on.
Go to your phone's main menu and enable Bluetooth. Depending on the model of your cell phone, your Bluetooth options may be listed under connections, settings, tools or extras.
Insert the Bluetooth Dongle into the USB port on your laptop. A dialogue bubble will pop up once your computer recognizes the device. Do not close this dialogue bubble until the device has been fully installed. Once it has, you will see the words "Installation Complete."
Go to the Start menu, then select "Control Panel." From here, open up "Network in Internet."
Choose "Set up a Bluetooth-enabled device," then click "Add." After this, select "My device is set up and ready to be found."
Find the name of your phone and click "Next." At this time, you will be asked to give a passkey. The passkey will have been supplied by the manufacturer of your Bluetooth dongle. Enter this same passkey on your cell phone. (You can use the Default code which 0000)
File Sharing
Right-click the file on your computer that you want to send to your phone.
Select "Send To" and then select "Bluetooth Device." A box will pop up asking you to select the name of the device from the list provided. From here, you will select the name of your cell phone.
Click "Next" or "Continue." The file will begin to transfer.
Accept the file transfer on your cell phone.
Hope it helped.
Thanks for using fixya...
Jan 26, 2011 | Cell Phones
How to connect to my computer via bluetooth as i want to send music to my phone (LG KS20)
Hi, You can install the the PC suite that came along with the mobile phone in your laptop. or search for bluetooth device from your laptop, your phone will get detected. just drag and drop your music files to the mobile icon. the files will be transferred. if its a desktop computer, you need a blutooth dongle.
Nov 02, 2010 | LG KS20 Smartphone
How should i send or receive data from other mobile.
  1. Use a cellphone with Bluetooth (wireless connection), or even a USB connection (which is a computer port). These are all good ways to communicate with other devices.
  2. If your computer does not have the hardware for a Bluetooth connection, then buy the adaptor, sometimes called a 'dongle'. The adapter plugs into a USB port. It will be quite cheap, something like 10 to 20 American dollars. This adapter will have software for the connection process, which lets you transfer files from the computer to your phone, and the other way around.
  3. Make sure your computer is equipped with Bluetooth technology (either integrated into the machine or a USB dongle) and active.
  4. Turn on Bluetooth on your mobile device.
  5. Turn on your phone and go into 'Settings' in the Main Menu
  6. Keep going down until you find 'Bluetooth' (Sometimes it may be under 'Connectivity)
  7. Click on it and find 'Turn Bluetooth on' (or something similar) and press 'On'. You can now send and receive files. Once you receive a file, it will most likely be under 'Received Files'. This option can often be found in the Settings or Connectivity menu of your phone.
  8. Pair your computer with your mobile device by making both devices discoverable (also known as visible or unhidden) in the Bluetooth options. Once both are visible, search for Bluetooth devices on your mobile phone
  9. Locate the name of your computer in the results list and select it.
  10. Enter a 4 to 8 digit passcode of your own choosing and press continue.
  11. Once your devices are paired, you can send and receive files.
  12. There are several methods to send a file to your mobile device. One method is to copy the file from your computer, navigate to your mobile device (often found in My Computer or My Bluetooth Places) and then paste the file to the phone. Another option is to right-click on the desired file and select Send To --> Bluetooth Device --> (mobile phone's name).
  13. While the file is being transferred, you should see a progress bar on your computer and/or phone. Once the file is finished transferring, a message stating such should show up on your device's screen.
  14. Find the transferred file on your mobile phone by using the phone's built-in file explorer.
Oct 20, 2010 | Computers & Internet
I have a generic bluetooth dongle it says it is a 2.0 EDR bluetooth dongle made in China just a cheap bluetooth but on to my problem i have installed the bluetooth all that is working fine it picks up my...
Sounds like the profiles are a match for sending but on some phones you need to set the phone as ready to receive the file. You should be getting a message that the PC is trying to send a file and it may ask for a pin code. You can also authorize the two devices, creating a bond that will by-pass this process. If you add your model phone, I can give more specific help.
Sep 24, 2010 | Adapters.com Bluetooth USB Adapater, USB...
Laptop will not discover bluetooth devices
just make the blue tooth visible like on the phone
Apr 14, 2017 | Nokia Mini USB Bluetooth Dongle w/...
Acer Aspire 1650 bluetooth useage
You can use the Bluetooth already in the laptop. You do not need a dongle to do the same. All that you need to do is pair the notebook and your bluetooth enabled device like your cellphone to be able to Transfer files.
Mar 17, 2009 | Computers & Internet
Cant get v.2 bluesoleil bluetooth dongle to transfer music from my pc to my sonyericsson v600i
ya u can share thro bluetooth but y don u use data cable instead... its easy and fast ...
Dec 07, 2007 | Sony Ericsson V600i Cellular Phone
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
