Question about Espresso RMI La Cimbali Espresso Machine
Our machine stops working for no apparent reason. We turn it off, unplug and wait a few hours or overnight and it has started again. But not today? any suggestions?
    President:
  • 1,618 Answers
I do not know what model you have but the first thing I would check is the Pressure stat and the Hi limit switch which sits on the element. Remove the hose from the boiler to the P. Stat and make sure it is not blocked.
Posted on May 03, 2010
Whirlpool front loader flashes lo fl
call the Whirlpool engineer and ask for a quote first as this can be expensive, have you tried to unplug the machine and wait 1/2 hour before trying again eric
Jan 07, 2018 | Whirlpool Washing Machines
Digtal answering machine not working.
I don't know yet if this is a resolution, but I'm going to try this tonight. Unplug all bases and remove all batteries from all handsets -- leave this overnight.
Here's the history of my problem. I rec'd this phone for my birthday. 3 weeks in, power went off in my building and answering machine part stopped working. I took it back to the store, and they gave me a new one. 4 weeks in, another power outage and I have the same problem. I called Panasonic, and they told me to unplug all bases and remove the batteries in the handsets for 'a few minutes' to reset the units. I waiting 10 minutes, and replaced all batteries and plugged in all the bases again. No luck, answering machine still did not work. I noticed, however that the phone did not reset as I still had all my phone numbers and caller id history.
I called my brother who is an electrician, and he advised me that the base has a 'capacitor(sp?)' and it will probably take a few hours for it to 'drain' so the phone will reset itself. His suggestion is to unplug all the bases, remove all the batteries and leave everything OVERNIGHT. By that time, the power store in the base should hopefully be wiped out and the phone should reset like new. I will try this tonight and let you know if this works.
Jan 31, 2009 | Panasonic KX-TG1033S Cordless Phone
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Sharp a/c-#AF-S85FX
The e1 code is operated by a timer which stops the machine every 720 hours of run time. There are 2 procedures to reset this.
1) unplug the machine. Hold down the power button while plugging it back in and waiting for a beep of about 5 seconds duration. Release the power button. Unplug the machine again. Resume trying to use it as an air conditioner.
2) unplug the machine. Hold down the Mode button while plugging it back in and waiting for a 3 second beep. Release the mode button. The machine will start. turn it off by pressing the power button. Resume trying to use the air conditioner.
If these do not work, the "clean filter timer" is broken and will require you to replace some parts.
(Aren't you glad there is a computer is almost everything?)
Jul 24, 2008 | Heating & Cooling
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
The remote to my pioneer elite reciver stopped working for no apparent reason. I changed the batteries but still I cannot control the receiver. HELP
HI;
I'm having the same problem. All that is needed for a quick fix is to unplug the receiver and wait a while and plug it back in. You might have to do the unplug and plug back in a few times and you may have to wait hours but eventually each time this has happened to me I've been able to get it working again. You will find this in the Trouble Shooting guide under Other Information. the problem I'm having is it keeps doing it and can be really annoying. Even the face controls go out and no control of the receiver is possible. For the money you would think it would be a bit more robust. It's acting like a Korean Microwave I bought about 15 years ago.
Apr 10, 2008 | Pioneer Elite VSX-9100TX Receiver
Network connection
It probably stops working due to the heat. The solder connection to the motherboard may not be up to par. To get round it I would purchase a PCI network card and use that instead. If the mouse bothers you, you can always unplug it, but it is something that you dont need to worry about.
Mar 22, 2008 | Computers & Internet
Ignition stays constantly on, How to fix it or shut it off
its a gas cooktop it has to be plugged in somewhere op e the cabinet and unplug it. possible that the electrodes got wet and click from a false sense of continuity, after being unplugged overnight that will sometimes be enough. you also might have a bad start switch on one of hte burners causing the machine to click automatically. try unplugging over night first
Mar 11, 2008 | Maytag 30 in. CSG7000 Gas Cooktop
Hp2410 unable to operate
Cleaning your appliance may very well take care of your problem. But if not make sure the drivers and the software have been installed. If they appear to be installed then uninstall them and restart your computer and reinstall them. If you have the same problem then take to a qualified service center.
Aug 06, 2007 | HP PSC 2410 All-In-One InkJet Printer
Wii stuck on download screen
try unplugging it then retry the updat my wii updated in about 20 or 30 minutes.
Jul 17, 2007 | Nintendo Wii Console
Espresso RMI La Cimbali Espresso Machine Logo
85 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
