How to change belt in teac x1000r reel to reel tape deck
Can you tell me how to replace the belt in the teac x1000r tape deck. What exactly do I need to take apart. thank you
    Sergeant:
    Champion:
  • 319 Answers
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
  • Sam Palermo
    Sam Palermo Oct 28, 2013
    I concur with this assement. I am a Teac Lead Technician and these machines have a lot of places you can get into troublle.
SOURCE:
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Replace belt on teac x1000r
The belt being broken is just the tip of the iceberg. Yes, people change them themselves all the time then they bring the deck to me when this does not work. Besides the belt, the capstan motor has to be determined good or not- sometimes a sticky belt can burn up the motor a $150 part. Typically, pots need cleaning, Flywheels should be extracted and oiled as well as capstan shafts cleaned and reconditioned- the Flywheels are particular as how they go in. I get units in with them reversed and another problem is created. The adjustment of tension arms requires a Tentelometer and the voltage references have to be set- they are usually off due to mechanical changes to the tension arms. The the calibration of the deck should be done. Also people are buying a wide belt in E bay and it does not work- I end up taking it out and putting in a correct sized belt. Rollers and Pinch Rollers need oiling and the washers put in where missing and so on.
If you are in Chicago area look up skywave Tape Deck Repair on the internet- I work on X1000R and X2000Rs all the time.
If in New Jersey Russ in in Emerson.
Feb 18, 2013 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
Teac x-3 belt kit reel to reel
Marrs Communications has belts for a lot of different models. I have bought from Fred Marrs before and his belts are the high end ones not Chinese garbage. That's who I would contact.
http://marrscommunications.com/
Nov 26, 2011 | Teac Audio Players & Recorders
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
Teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Jan 23, 2009 | Audio Players & Recorders
Teac X-1000r broken drive belt
Gidday Chino
You can get a FRESH belt kit from here. Cost you $10 plus some post. There is a new pinch roller listed against this old girl also could be worth replacing at the same time when you service the deck.
regards
robotek
Aug 05, 2008 | Audio Players & Recorders
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it [email protected]
Nov 24, 2007 | Audio Players & Recorders
824 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
