Question about Dishwashers
Noisy pump This is supposedly the quietest washing machine. It is until the pump comes into operation. It pumps incessantly for up to ten minutes before the spin operates and it is extremely noisy. I have had an Hotpoint engineer visit and he brusquely said that this is normal. I wouldn't have purchased it if I had known this. My previous Zanussi was much better. Was the engineer correct?
  • 901 Answers
It depends on the design, the way it is mounted on the machine matters a lot.
Sometimes pump makes noise due air trapping. Check your water flow. Add 10 liters of water in the chamber direct and close the door. start the machine in usual way. If there is no noise it is air trapping in the impeller.
Posted on May 03, 2010
Hi, have a problem with my hotpoint wfm940 washing machine. It had an error f5 which relates to the drum not draining, found rubber bands in the pump. Machine isn't running any cycles now, it will spin,...
Try removing the plug or switching off the washing machine and leave it for about ten minutes. Hopefully this will reset the electronics and allow normal operation again..
Jan 02, 2014 | Washing Machines
Error code F-21
this code means a long drain meaning if it takes over 8 minutes to drain it will show this code and possibly "suds" code too,first try unplugging the washer for 30 minutes as this clears the central control unit if this is the case,if this doesn't help then check the drain pump located below the washer tub for any obstructions such as coins etc.if this isn't the case make sure drain pump is operating and not noisy,if it is then the drain pump needs replacing
Oct 20, 2012 | Kenmore HE2 Plus Front Load Washer
Pump cutting off
the pump is not suppose to run all the time.it should cut off until you pull draw handle . when handle is pulled pump should run for ten seconds or so.
May 06, 2012 | Taylor 8756-33 Soft Serve Two Flavor Ice...
Will not pump out water
try checking the belt,might need to be replace are good be the motor over heating
Apr 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
When on spin cycle makes noise & water comes out under machine. How do you take off back of machine to get to the pump area ?
Possible drum bearing problem , seals leak into bearing chamber and beyond , bearings seize and become noisy. Pumps get noisy but rarely leak.
Nov 09, 2009 | Washing Machines
The spin cycle will not run on the regular wash. Once the switch points to the SPIN, the noise is present, but there is no movement within the washing machine. The dial continues to move until the supposed...
Check the pump drive belt. It may have come off.
Sounds like the motor is spinning but the pump belt isn't spinning the pump.
Pull the front cover and look under the machine for the belts.
K
Jul 09, 2009 | EuroTech Washing Machines
Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
Apr 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Very loud noise when washer is in wash mode,
IT COULD BE SOMETHING IN THE TRANSMISSION. DOES IT AGITATE AS IT IS SUPPOSED TO? IF IT DOESNT, I WOULD SUSPECT THE TRANSMISSION, IF IT DOES, i WOULD START BY LOOKING AT THE PUMP. THERE IS A PIECE OF METAL THAT HOLDS THE BEARING CENTERED IN THE PULLEY OF THE PUMP. OVER TIME, THE METAL CAN COME OUT AND MAKE CONTACT WITH THE BOTTOME OF THE PUMPS MOUNTING PLATE CAUSING QUITE A NOISE. ALSO, DEPENDING ON WHEN YOU BOUGHT YOUR WASHER, THOSE MACHINES HAD A TEN YEAR PARTS WARRANTY ON THE TRANSMISSION.
Jan 28, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Not spinning
I found my Classixx 1200 express with a flashing spin light, the water wasn't up in the drum, so I moved the selector to rinse, and pressed start, pump was noisy but worked, I could hear water going into the drain, thinking I'd got a blockage in thye pump, I drained machine using small hose and inspected the pump orifice at the front of the machine (towel handy to catch spillage.
No obvious blockage and the pump could be turned by hand, tried rinse again with water feed turned off, (otherwise it pumps for a while and then lets water in to rinse - which comes out the open pump housing!) I could see the pump impeller spinning but also sticking, its was also noisy.
Solution - new pump, according to my local spares shop, the pump is available as either motor & impeller (back half), or complete with black housing that the pipes fit to, to get the front cover off, and to remove the pump, you need a "star" screwdriver or key, and a pair of pliers to undo the hose clips - have a bowl ready to catch the water, and make sure the machine's unplugged before you start!
Jul 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
