Question about Northstar Generator 18 Hp, 10,000 Watt, Gasoline
No 240V 110 plugs work fine. 240 plugs don't work. Any ideas?
  • 905 Answers
Check for a circuit breaker that is tripped, as well as a switch that enables 240volt (at the cost of 120 volt current being cut in half.). The switch puts the alternator windings in parallel (120volt full power) or series (240 volt @ half 120volt current).
Posted on Jun 12, 2010
Can Singer 7258 Stylist be used in a Country like India with 220 - 240 voltage? Is there any UK model for the same?
the machine comes in two versions european {220-240v}
or american {110v}
you need to use a transformer to give 110-240v
the current this machine uses is less than 3amps
so a 3amp 110-240v converter is easily found on ebay for $10
Mar 12, 2015 | Singer 7258 Sewing Machine
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Does the wii have a fuse? Unfortunately my daughter plugged the 110V device in 240 outlet & on-ned it.
Hi. I am pretty much sure that your Wii has no prblem. Just purchase a new adapter and werything will work fine. I suggest you buy international adapter (110-240v)
Sep 13, 2010 | Nintendo Wii Console
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
Kenmore catalyst electric dryer. about 3 yrs old.
You may only be receiving 110 volts, instead of the 240 volts needed to operate. (Thus, only the light coming on)
Did you reset the dryer circuit breakers?
Are you receiving 240v to the plug?
-Chad
Jan 21, 2009 | Kenmore 659 Electric Dryer
Lap tops
It sounds like what you are looking for is a Step up/Step down converter. I do not know of any laptops that come with a 240v adapter since most things here in the U.S. run on 110v.
Do a search on Google or such for a 240v 100v converter.
May 22, 2008 | Apple MacBook Pro Notebook
Northstar Generator 18 Hp, 10,000 Watt, Gasoline Logo
174 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
