Question about Dometic Rooftop RV Air Conditioner
Ilet the filter on my unit get clogged and it quit cooling. after i cleaned the filter it still doesn't cool.
    Novelist:
    Champion:
  • 246 Answers
"If your dirty filter caused your problem,' it was because it restricted the air flow across the cooling coil. Often if the filter is clogged then the air will divert around the filter itself - and clog the cooling coil too, in which case you will need to clean the cooling coil.
The cooling coil is looped in a coil (hence the name) and is comparable to a car radiator. You will need to clean the fins (that are entwined around the coil) so that air - can flow unrestricted, over the coil.
This can usually be accomplished with a brush of some sort. Often you can use your fingers to peel the moist mat of hair and dirt off the front of the coil.
The problem (usually) is getting to the coil, because once you get to it - it generally is not that hard to clean. Your goal is make sure air flows thru the fins and over the coil - unrestricted of dirt, hair, or whatever.
Remember - many things can cause an AC unit to 'not cool' besides the filter being dirty - which is why I prefaced my answer with 'if your dirty filter caused your problem'
Good Luck!
Posted on May 03, 2010
I have a Haier Wall Air Conditioner. It's on cool
Filter may be clogged. I have one and it has a filter which I clean regularly.
Sep 11, 2012 | Heating & Cooling
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
Window unit is freezing up and it does not cool the room
Ths is usually caused by the air intake filter being dirty or clogged. Remove the filter and clean as necessary. If that doesn't solve the problem, there may be a small leak in the refrigerant coils. In which case, replacing the coils will be required and the compressor will have to be recharged with refrigerant gas.
Hope this helped you and thanks for choosing FixYa.
Aug 27, 2011 | Heating & Cooling
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
Unit ices up and quits cooling
There are a couple of things that contribute to the problem you're experiencing:
1. A dirty or clogged air intake filter. Turn unit OFF, remove and clean the filter. If filter is washable
be sure filter is thoroughly dry, before reinstaling it.
2. Cooling fins are dirty. Turn unit OFF, remove the outer shell of the AC unit, if necessary and
clean the fins with an old toothbrush and a vacuum cleaner.
3. Humidity level in your area is extremely high. This is Mother Nature's problem and is not readily
solvable.
4. Defrost sensor is not functioning properly. Replace sensor.
5.. Low refrigerant gas in the AC's compressor. Have compressor recharged.
Hope this helps you trouble shoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Friedrich TwinTemp EL24J35A Air...
Jusrt bought a mobil home with an Interherm unit. I live in Louisiana. When the air was hooked up is didn't cool very well. The fan motor outside had to be replaced. I was told it was the wrong...
There are a few things you can try.Close the vents half way in rooms your not using often too force more air to where you want it.
Inside coil and filter may be clogged or dirty.Change filter and clean coil with a degreaser spray,simple green works well mixed with water.
Thermostat location? is it in a common area like the living room.If not it should be there.
May 10, 2011 | Intertherm P3RA-024K Air Conditioner
I have a Goodman system and I have water leaking from the the small box next to my furnace. I have what looks like 3 lines running from unit to this box. One is a small copper one, another is a line...
the clear plastic hose is the condensate drain .. indeed they clog frequently .. lthat will allow water to overflow the pan that is desined to capture condensed water from the evaporator.. the plastic hose and the pipe it is attached to need to be cleaned out periodically ... allowing water to overflow can damage other things so its important to get the drain cleared .. however that drain has little to do with cooling efficiency .. your lack of cooling performance could be another problem ... sometimes the evaporator coil gets clogged (large finned unit behind where the overflow hose is attached inside furnace) .. that has to be cleaned once in a while but is tricky to do ... how often depends on how good the furnace air filter is and how often its changed ... as the evaporator becomes clogged with dust the cooling efficiency goes down .. same with the outdoor unit ... you have to wash out leaves and such periodically from the condenser coils .... if every thing is clean but the cooling efficiency is still low then have the unit checked for refrigerrant pressure .. it could be low .. of course make sure the furnace filter is not clogged ... also for cooling make sure all of the registers are open ... closing some can reduce overall efficiency ... make sure the outdoor unit fan is working properly ..
Jul 25, 2010 | Goodman Heating & Cooling
My frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
May 25, 2009 | Frigidaire FAC084N7A Air Conditioner
No cooling, suction pressure reads vacuum Split AC
The unit is restricted, reprocess the system, flush and vacuum it thoroughly.
Mar 24, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Dometic Rooftop RV Air Conditioner Logo
74 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
