Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor ERD30 oven trouble
I have a dacor erd30s60ch dual fuel. The oven will not heat up. I put a new element in but that did not solve the problem. I have 120v to ground on both terminals with the element removed but not 240V across them. I looked for the reset that was already mentioned as a fix but could not find it Any suggestions? Thanks, Keith
  • 1 more comment
  • keithctc Mar 26, 2008
    I only have 120 at the element. I'm not sure what the thermal fuse looks like but there are two identicle 1" round components with two spade connectors on each with a small, square, red reset button. One has Black and black wires - this one has 120v on both sides only when you push BAKE. The other one has orange and white wires- there is no voltage on either wire even after pushing bake. Thanks
    I could not locate the thermo fuse yet. This picture shows the two items with th red reset buttons on them. The one on the left has voltage on both sides only when youpush the bake button. The one on the right does not have any voltage even after you push the bake button Is this normal?
  • keithctc Mar 27, 2008
    I disconnected both wires on both switches. There is continuity when the switch is in its normal state, when you push in the red button the circuit is broken. Both switches act the same. One of these switches has 120v on both sides of it when you push the BAKE button on the range - the other one has no voltage at any time ???
    Genius:
  • 1,665 Answers
You must inspect all switch contacts, wire continuity, and connections to be ok.
Posted on Mar 25, 2008
  • 7 more comments
  • Anonymous Mar 25, 2008
    Turn off power to the stove at breaker panel.
    Open oven door.
    Remove screws from vent panel below the control panel on front of stove.
    Directly behind automatic door locking mechanism is a U-Shaped connector with a red button in the middle. Press down the red button.
    Replace vent panel.
    Restore power.
    Set clock and oven should work.
  • Anonymous Mar 27, 2008
    As seem if the other end of white is that you found loosen, it may go to neutral or may ground.
    You must check carefully.
    Make sure using a multimeter if the shown white end has straight continuity with the loosen end.
    I sorry my previous suggestion sent to you by error (it is for another question)
    Make sure that both two shown swithes with red button operate properly.If it is possible disconnet wires and check their resistance with button pressed. Measurement should be Zero ohms.
  • Anonymous Mar 28, 2008
    As the two swithes change state when red pushed or not, they seem to be ok.
    You have changed the element whith new as said;
    Did that removed found damaged?
    Have you placed the new right in order to ensure the circuit is not open at contacts of replaced element?
    Did you check also resistanse of the new element in comparison with the old? (a very rare case for the new to be defect).
  • Anonymous Apr 04, 2008
    Have a look at manual below:
    http://www.dacor.com/Dacor.Website/WorkA...
    This Use & Care Manual is designed to enable
    you to properly operate and maintain your new
    range. Please keep this manual handy for easy
    access and quick reference......
    At view select >"ranges"> ERD30s06
  • Anonymous Apr 05, 2008
    1. ERD models must be connected to a grounded,
    metallic, permanent wiring system. Alternatively,
    a grounding conductor should be connected to
    the grounding terminal or lead on the appliance.
    2. ERG models must be connected to a grounded
    receptacle. Failure to do so may result in an
    electrical shock hazard.
    3. Do not use an extension cord with this appliance.
    Such use may result in fire, electrical shock, or
    other personal injury.
    4. Do not install a fuse in the neutral or ground
    circuit. A fuse in the neutral or ground circuit may
    result in an electrical shock hazard.
    Have a look page 8,9.
    Genius:
  • 3,422 Answers
HI,
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
when you get your meter . put the oven on bake and check your power on the bake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Mar 25, 2008
    The problem is with your Thermal fuse only since it has got overheated and burnt.So i strongly recommend you to replace the thermal fuse.
  • Priya darshan Mar 26, 2008
    You can view the picture of the thermal fuse from HERE
    If you need more info about thermal fuse you can click HERE
SOURCE:
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
My Dacor RSD305 duel fuel oven does not work.
you need service
when set the display starts off at min temp
if no heat rise is present it will shut off
check your house breakers first
Jun 06, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor oven will no heat.
dacorservice.com very likely has your answers. Good Luck and Happy New Year!
Dec 27, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven enamel chipping
Never heard of such a problem, you are the first to post it. There is no fix for this.
Apr 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD30 will not reach or maintane setpoint
read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Dec 31, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
875 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Jaime Hernandez
Ekse
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
