Question about Kenmore 24 in. 17022 Built-in Dishwasher
Clean light keeps flashing, cant get it to reset. What can I do?
Last night was running dishwasher. Mid wash it flashed clean. It has been flashing clean sence. I turned off power to reset it. This did not work. It is still flashing clean. What can I try? Thanks for any help.
    President:
  • 949 Answers
Hi, if the clean light flashes it is indicating the was no rise in water temperature during the water heating cycle. This link below will explain things that could cause it and tell you how to reset the control so you can wash for now. Let me know if you have questions.
Be sure to follow the 'key dance' just as specified'
Thanks!
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 03, 2010
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
Clean button won't stop flashing and it won't start, got interrupted mid cycle.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Feb 05, 2011 | Kenmore 24 in. 17039 Built-in Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore elete dishwasher flashing light clean
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Kenmore 24 in. 17022 Built-in Dishwasher Logo
172 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
