Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
My kid dropped the camera. The lense won't move
My kid dropped the camera - Canon ixus50. The lense won't move out when turned on - it seems the turning mechanism is stuck so the lense is wonjy and gives an error E18
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
I drop my camera ixus 9515 canon
Before taking your camera to an authorized Canon repair shop try these procedures. If you need to contact Canon, start here.
Mar 26, 2013 | Canon Cameras
I cannot turn off camera. Lense error appears.
you must have dropped or banged the camera,same thing just happened to me. i'v done some looking on the internet and it seems we have to bring the camera to a repair shop,but get a quote for the repair because one site advised just to buy a new one as its very expensive to fix. i'm going to get a quote and 1st for the work,just incase.
Mar 18, 2010 | Canon PowerShot SD1000 Digital Camera
I dropped my camera today. Seems like the lense
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 30, 2009 | Canon PowerShot A80 Digital Camera
Dropped the lens, the focus ring won`t move
You can send it to the canon-service but i think it will be cheaper if you buy a new or used one.
Jul 20, 2009 | Canon EF 50mm f/1.8 II Lens
My sd750 will not start up
Does the lens cover move when you do this? If it doesn't, it sounds like that might be the problem.
Jul 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon A540 powershot freezes with Zoom lense still out.
Probably the most common failure for all digital cameras, a lens error. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 08, 2009 | Canon PowerShot A540 Digital Camera
Polaroid i733, purple picture
I got this camera or christmas .Worked good for awhile. Screen went purple and now its not working.
Apr 03, 2008 | Polaroid i733LP Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
My Canon Powershot SD400 won't turn on and lense won't go back in
Unfortunately the lens assemblies in these compact digital cameras are quite delicate. The drop probably knocked the barrels of the lens out of alignment preventing it from moving. You can try to GENTLY twist the lens back and forth, you may be able to click it back into alignment allowing it to function normally. If the gentle manipulation fails to fix the problem you will need to get the camera serviced by a professional. There are quality repair services on the web who will work on your camera. David Millier Advance Camera Repair
Mar 05, 2007 | Canon PowerShot A520 Digital Camera
Zoom Lense stuck on Canon EOS Digital Rebel
are you pushing the release button?  was it dropped? does it move at all?
Jul 26, 2006 | Canon Digital Rebel / EOS-300D Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
