Question about Hitachi 51F59 51" HDTV Projection Television
Computer to HDMI outlet of Hitachi HDTV rear projector
I plugged in my computer through the HDMI outlet on my TV and can't figure out what channel or input i need to have the TV on to show the display of my computer??
  • 27 Answers
The TV should be pretty simple. It is generally going to be HDMI 1, 2 or 3. If the TV won't tune to one then it doesn't detect a signal on that port. More likely, there is a setting either in your Graphic Adapter software or in Windows to output to this port. Windows doesn't turn anything but the RGB port on by default.
Posted on May 02, 2010
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do the hmi on tv withe control
How to Enable HDMI-CEC on Your TV, and Why You Should
www.howtogeek.com/.../how-to-enable-hdmi-cec-on-your-tv-and-why-...
Jan 16, 2015 - The devices can have some control over the TV, and the TV can have some control over ... AOC: E-link; Hitachi: HDMI-CEC (Thank you, Hitachi!) ...
How to find out if your device is HDMI CEC capable?
hdmicec.blogspot.com/.../how-to-find-out-if-your-device-is-hdmi.html
May 18, 2012 - Hitachi - HDMI-CEC ... You can control your computer with your TV'sremote control and you can set up that your laptop shuts down or goes to ...
[PDF]OG S606 U516 Eng - Hitachi Service
Dec 26, 2015 | Hitachi Gst Hitachi 46" Class LED-LCD...
Projector worked great with an old computer. Now my computer is HDMI and parallel port ready, cables provided with the projector, it won't talk to my computer. What am I doing wrong?
you can be able to use that old projector. for that you need an "HDMI TO VGA" converter .Have added the picture. you can find it in any computer accessory showrooms or you can buy it online.
www.electro-medical.blogspot.com
Aug 25, 2015 | Hitachi CPX5 Projector
Help hooking up to computer
No hdmi on computer or projector?
I assume rca style plugs on projector (red/white/yellow) type into google "hdmi to rca" there's a cable for that.
Aug 03, 2012 | Hitachi Televison & Video
Want to hook it up to my computer
Use an HDMI cable and program the computer to find the TV.
Jul 03, 2010 | Hitachi 57F510 57" Rear Projection...
I have a Hitachi 57F500 HDTV SRS TV and can not get any chanels
unplg tv 4 30 min plug bak in if does not reset u will have remove supply voltage to computer clock 2 do this u must go into back of tv and look on board until u find a whats looks like a watch battery remove it wait 6 minutes reinsert it this just reset the clok in the microprcesser dumped the ram this should fix ur problem everthimg should go back 2 factory seettings read manual
Jul 25, 2009 | Hitachi 51F500 51" Rear Projection...
Cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
No audio
Thanks FixYa...found the answer on your forum..selected PCM in the audio menu on my HDDVD player..plugged in the same HDMI cable and now have sound...saved me a bunch of money from buying a more expensive HDMI cable..Thanks again
Nov 25, 2008 | Hitachi 51F500 51" Rear Projection...
I have a Hitachi 53UDX10B 53 in. Rear Projection HDTV.
Hello iehoryna,
The answer is yes, you will be able to pick up and display HD channels. You will have to use your component video cables between your cable box and your TV. Component video will allow you to view low to medium end HD pictures.
I hope this helps,
Thank you,
Shuttle83
Nov 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
250 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
