Question about Nintendo Wii Console
Screen is compressed both horizional and vertical
Have audio, under the options menu with the Wii system you can select either standard or HDTV for the video options. System was on standard when I opened this menu suspect I selected HDTV. Is there a way to go back to factory settings and re-start system over? I do have an HD TV and was using the standard connections that come with the Wii system. Prior to entering this menu area had both audio and video.
    Problem Solver:
  • 17 Answers
Hi Rod,
If you can still see/read what's happening on the screen, go back to the Wii Options screen, select "Wii Settings" on the right, click the Screen option, and make sure "Widescreen settings" match your TV (if in doubt, choose 4:3). Click confirm, then click "TV Resolution" and ensure it is on Standard 480i. With these settings, the Wii should be viewable on almost any TV.
Posted on May 03, 2010
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Where to start.....alright. I currently have a softmodded Wii console, and I recently bought third party component cables for it. The cables work fine under Standard TV resolution (480i), but when I change...
From the Wii Channels menu, click the "Wii" button on the lower left of the screen. From there choose: Wii Settings > Screen > TV Resolution. In this menu, click on the "EDTV or HDTV (480p)" option and then click "confirm".
Aug 07, 2013 | Nintendo Wii Console
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
I bought a used Wii and I cannot delete the previous owners name and system. How do you do it?
1. Turn your Wii on and wait for the main menu to load. Click the Wii Options button in the lower left of the screen.
2. Enter the "Wii Settings" menu by clicking button with the wrench icon. Scroll to the last page in the menu.
3. Choose "Format Wii System Memory" at the bottom portion of the screen. Read the warning and select "Format" to reset your Wii to its factory settings.
Thanks!!
EJ Kudelka
Apr 29, 2011 | Nintendo Wii Console
How do i connect my nintendo wii to my wireless home network
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Feb 28, 2011 | Nintendo Wii Console
Wii console to Philips HDTV Connection not working
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Jan 26, 2009 | Nintendo Wii Console
Wii VC games won't play on hdtv
I had the same Black Screen problem and I finally have a fix for it!
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
Sep 28, 2008 | Nintendo Wii Console
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
It got stuck when beginning a game
go to the shop and tell them ur problem and get a exchange
Sep 02, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
90 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
