Question about Sony Playstation 3 (PS3) Console
My playstation does not turn on at my girlfriends house
F8E1 code on my whirlpool duet. The plumbers were working in the house and shut the water off to the machine, then my girlfriend ran a load without turning the water back on.
ROFLOL and how did that work out for her I've heard of dry cleaning but dry washing . quite possibly all that burnt out is the water inlet valve.
Aug 04, 2015 | Whirlpool Washing Machines
8002a203
How come on my ps3 my girlfriends account is the only account that can be signed in and when I sign her in two of her friends are online as well and when I try I get that 8002A203 error what's up with that?
Jan 17, 2013 | Sony Playstation 3 (PS3) Console
Playstation 3 does not output to my Mitsubishi 62825. It has in the past. I've tried RGB and component. Neither work. Using the same cables it works fine with my girlfriends Sony Bravia. The tv has...
Is your girlfriend's television higher resolution? If so, the ps3 may be configured to output a signal that is too high for your mitsubishi. With the ps3 off, insert either the component or the rgb to the back. The turn on the main ps3 power switch so that the red led turns on. then hold down the 'power on' button. it will beep initially, then beep after about 3 seconds. This simply resets the output to the connected cable in a normal resolution.
If this fails go to settings>video output> and play around with the settings there. note you may have to do this on ur girlfriends tv to be able to see what you're doing...
Aug 26, 2011 | Mitsubishi WD-62825 62" Rear Projection...
IP address issue for PS3
reset the modem and router it is not issuing the ps3 a new ip ...reset should solve the issue
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
Hi i set on ps3 up on my tv with a hdmi cable and done the settings on the ps3 i ve move my ps3 round to my girlfriends house on her tv but not with hdmi cable the normal scart cable with the yellow red...
You have to go Back to the original set, plug it all in again, NOW change the output to anything else, Now, shut down machine... NOW you will be able to use it, elsewhere.
Feb 22, 2010 | Sony Playstation 3 (PS3) Console
Turnt itself off and now it wont turn back on?
More that likely its a heat sync issue and your CPU and GPU need to be reseated. email dwdpcrepair@gmail.com for more information
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
It wont work
Try replacing the battery with a new one. I have had batteries short out in the past.
Jun 12, 2008 | Sony PlayStation Portable (PSP) Console
I have a problem!!!
Sounds like a tough problem.
If your GF left you for a GF well maybe her mom want to switch to women too, and mommy sees you as a means to an ends. :o)
Mar 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
