Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
My trekstor data station maxi n u 150 gb wont work on windows 7, it works on my sisters but not on mine. My motherboard is gigabytes series, could some drivers be missing
  • 12 Answers
SOURCE: DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Posted on Jul 29, 2009
SOURCE: Drive cannt be detected by laptop
I have trekstor 500gb external hardrive its making a funny clicking sound and doesnt be read by my laptop is it damgaed?? and if so how can i get all my things off it?
Posted on Feb 09, 2010
slaphappy
  • 24 Answers
SOURCE: where can i get accessories and power adaptor model MSMTU EM 8
Try The Manufacturer Web Site ... http://www.trekstor.de/en/products/detail_hdd.php?pid=17
Posted on May 10, 2011
bronk50
  • 27725 Answers
SOURCE: Neither my pc nor my
this could be a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Posted on Jun 07, 2011
bronk50
  • 27725 Answers
SOURCE: My computer does not reconize my Trekstor
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Oct 04, 2011
Windows 8 wont see my Trek Stor hard drive
See if your product is listed at the official manufacturer site
http://www.trekstor.co.uk/downloads-en.html
, or contact them there. Be very careful with other 'third party' sites that offer drivers; many are unscrupulous sites that will give you a 'driver' that contains spyware, or makes things even worse.
Dec 02, 2013 | Trekstor DataStation maxi m.u SATA 3.5"...
Neither my pc nor my tv don't recognize my Trekstore MovieStation Maxi t.u 1000 GB, what should I do?
hope this helps
Jun 07, 2011 | Trekstor 88550 MovieStation maxi t.u 500GB...
I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
Good day, I cannot access my TrekStor external hard drive. Is there a way I can get it to work without formatting it and losing the data? I am running Windows 7. Kind Regards, Dries
Hi AHPretorius:
Do you have access to a Windows XP machine that you can try to use the drive with? Maybe a friend's computer? I would try using it with such a system and run chkdsk on the drive to make sure that the partition is healthy; otherwise, you might want to buy the DiskInternals program that may be able to help you revive the partition.
http://www.diskinternals.com/partition-recovery/
Please feel free to ask follow-up questions in a reply here.
Thanks for using FixYa and Happy New Year
Jan 07, 2011 | Trekstor Datastation maxi t.uch 500GB 500...
How do I use the network resouce to fix my problem?
Connect the Trekstor to your network, and be sure that it has an IP-address.
On Windows, click Start
Click Run
Type \\192.168.xxx.yyy
where this is the IP-address assigned to the Trekstor.
The windows that opens will be a window onto the Trekstor's files.
Dec 31, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Datastation m.u stopped working : (
Dropping a drive can be catastophic but usually isn't.
I suspect you may get lucky and find out it's just some of the circuitry in the trekstor shell that is damaged.
Take the Trekstor unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
100 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
