My tv isn't receiving a signal. I've tried tuning it and it still can't find any channels.
  • al_fc May 02, 2010
    Model: LT - 19DK8ZJ ( JVC)
    I do have cable for receiving channels
  • al_fc May 03, 2010
    yes
  • 10,594 Answers
Let me know your tv model number and brand info to check its related manual for tuning section.
Model number info would be written on label pasted at back of tv.
Do you have cable for tv channels or air-antenna?
Thanks.
Posted on May 02, 2010
  • Shahid Electronics
    Shahid Electronics May 02, 2010
    Do you get Cable/ Antenna section option in tuning Menu?
    If yes, then make sure to select Cable and scan tv channels and if that does not solve tuning issue then I would check Tuner that sounds defective, its mounted on main board of tv and coax cable pin directly goes in Tuner.
    Is it first time that tv hooked with cable or it was working fine before and recently started no-signal problem?
    Thanks.
3 Suggested Answers
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
So, I couldn't get the tuner to work (tried everything). Eventually I realised the cheapest solution would be to buy a digital set top box, and use this as the tuner instead of relying on the one built-in to the TV. Works fine.
But yes, I won't be buying another Panasonic in a hurry.
Posted on May 24, 2008
SOURCE: Cannot find freeview/digital on our new TV
problem as above please help
Posted on Sep 10, 2009
I have an older model Durabrand t.v. I'm trying to connect my satellite to it but the channel got changed. How do I get the t.v. to the correct input to use the satellite without a remote?
Connect and put on both TV & Sat Receiver, then on UHF channels, auto or manual tune the Receiver's output signal, try to fine tune if auto or manual does not tune well.
Nov 13, 2014 | Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
When I tried this out in the store, it picked up Al Jazerra, which is a cable channel and a couple of other cable channels but no DTV over the air channels. I purchased it since the store said they had...
Having weak signal are the most usual cause of not having it memorize in your flat panel TV channel when you re-scan to tune your flat panel TV. You will need a strong antenna receiver if you are trying to received a terrestrial channels. If still you got weak signal, you will opt to use an antenna booster, you need to get assistance from TV technician about doing this. Changing flat panel TV will not help, until unless the TV is equipped with strong tuner receivers (boosted type)
Jul 02, 2011 | Televison & Video
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
Toshiba 26AV500U This is being used as a 2nd set connected to a DishNetwork receiver. The set must be tuned to channel 73 to receive the signal, and no matter what I try the TV will not recognize 73 as a...
Tries tv unplug,replug it back like about an hour later.For forcing the tv do a resetting itself back to the factory setting.The tv now should be recognizing channel 73.
Feb 26, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
DVD with RCAs, TV with Scart. Have an adaptor but no joy. Why?
The dvd has Y= video composite, R= Right channel audio, W= Left channel audio these are the common jacks of electronics, Now the G=Green,R=Red,B=Blue are usual Component VIDEO OUT/IN for higher video resolutions, this could explain no video picture, try the Y=Yellow to Y=Yellow from dvd to TV then set tv to a VIDEO input 1 or 2
Feb 06, 2009 | Panasonic SA-HE100 Receiver
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Insigna ns-dxa1 converter
You might try useing a higher bandpass diplexer
Apr 24, 2008 | Audio Players & Recorders
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
