Question about GE Refrigerators
Ice forming on the back of side by side 17 yr old fridge
The fridge is not as cold as it should be and there is ice forming on the bottom - back- of the freezer. it is a 17 year old GE side by side with ice dispenser in the door.
  • GE Master
  • 1,606 Answers
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
Posted on May 02, 2010
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Ice on coil in freezer
may be thermostat, need a professional
Feb 28, 2012 | Frigidaire Refrigerators
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
I have an ONLY THREE yr old!! Kenmore side by side fridge w/ice maker. Refrigerator is cold, but freezer stopped freezing. I cleaned the condenser coils. didn't fix it. service tech came out, opened up...
not realy its the refrigerant gas thats leaked,, call the guy back and demarned he fixes it under the warranty,,,and dont take "no" for an answer,,, lurn to kick bu** to get whats yours
Nov 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 10 yr old fridgidaire side by side in the door ice and water and the top section of the freezer and fridge are not cold but the bottom shelves are okay.....any ideas?
Good day,
That is typical of the freezer fan motor not running. Open the freezer door and see if you can hear and feel the fan motor running.
If not replace fan motor. You need to remove the back panel in the freezer compartment to access the motor.
Nov 05, 2009 | Refrigerators
Regulating Temps on Whirlpool Side by Side
well i think you know what this is!!!!
you moved it and it got upset about it?
but some freezers need to be dead upright
or,,,its the darn thermostat's there playing you up like mad if you cant control them there on there way out
best bet is have new ones fitted or just dump it all together,,after all think of how much that floor is worth? and how much ice cream do you need????
ps,,,i use a hammer drill to get my ice cream out the tub?? have you ever tryed "fried ice cream" its realy
"""""yucky"""""??? (sorry im mad you see)
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
