Question about Toshiba W603 VCR
How to set the clock without the rem remote? can't program the vrc, don't have the remote, so I can't set the vcr up.
4 Suggested Answers
  • 979 Answers
SOURCE: setting clock
Not possible-sorry...accordianman
Posted on Feb 15, 2008
SOURCE: Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Posted on Jan 12, 2009
  • 21 Answers
SOURCE: Toshiba VCR auto clock does not work, not way to set it. Please answer right away
you know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Posted on Mar 04, 2009
Need to program a QuantumFX REM-1114 Jumbo remote to a panasonic VCR
If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 08, 2014 | Innovage Jumbo Remote Control
WAT R THE CODES TO A QuantumFx rem-115
These are the setup codes for Orion VCR.
0256 0310
Aug 27, 2012 | Big Button TV Universal Remote
I have a sharp tv/vrc combo without a remote. I'm using a universal remote but wont let me get into the menu. I need to change it from cable to air. Can someone help?
For sharp TV-VCR Combo with universal remore control,
1/ Start by pressing SET & TV at the same time, the LED goes solid RED
2/ Press 009 or whatever code works for your TV.
3/ Confirm that you can now use your control to flip channels..
Then,
4/ Just press the blue button 2-/12. That allows you to change from cable to air and vis-versa. Hope that helps.
Ade
Jul 04, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
URC-4021B00 codes
http://www.oneforall.co.uk/us_US/support
May 21, 2009 | One For All URC-4021 Remote Control
I have a quantum fx REM-100 remote control and i need the codes for a quasar tv
I bought a Quantum Fx (REM-102) TV remote control for VIZIO TV but the remote control don't response
I did intent some codes to control programming but don
Apr 24, 2009 | GE JASRM24912 Remote Control
Vcr clock setting
Probably you can't. That's a big pet peeve of mine with A/V equipment these days- so much of the control is by remote only and if it dies your machine is almost useless
Mar 05, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
I have a sylvania vrc that i bought used without a remote how can i change vcr speed from sp to SLP
Get a One for All remote, find the code you need, then go to their web site and ask for the Extended Codes for the code you used for the vcr. These remotes are full of functions that can be used in this manner.
Aug 20, 2008 | Televison & Video
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
How to set clock on Orion VCR VR0419
Most late VCRs require the remote box to set the clock, timed recording etc. Assuming you have the Orion remote, it should have a programming or menu button, and the function you need can be selected from a list of options. If the remote is an aftermarket unit (non-Orion), it must have the capability to do the advanced setup (clock set etc.). Many aftermarket remotes only do basic channel selection, and tape functions (play, rewind, stop, etc.).
Apr 24, 2007 | Orion VR0419 VHS VCR
Toshiba W603 VCR Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
